Is R1 T2 DVD a Superbit?
Discussion in 'General' started by :: Phat ::, 13 Nov 2002.
  1. :: Phat ::
    :: Phat :: Oooh shakalaka!
    7 Jun 2002
    I was watching my Terminator II R1 DVD last night on my newly chipped Sony DVP-F11 (www.techtronics.com) and was playing around with the views, when I noticed it was running at 448 transfer, thinking this was quite high i stuck in a normal DVD, which ran at 192, every other DVD i have ran at 192 or thereabouts, except for my Panic Room DVD which is a superbit, and runs at 448+ so I was just wonderin, was T2 a superbit, because there are no special features on that side of the disk?
    Also, if you think 448 is high, the Queen DVD I bought my pa runs at 1395 (or so) because of the sound channels!!
    Also T2 R1 "Easter Egg" place the DVD in the drive and select either Theatrical or Special, now using the remote enter 8 2 9 9 7
    which in american date format is the 29th of Aug 1997, I'm not sure about R2, try 2 9 8 9 7. When you do that both eyes of the terminator light up and you get the extended special edition, which includes the bit where the T1000 is searching the room, and replaces the usual ending with the "Future Coda" ending.
    Aaaaaaai :clap:
  2. MrDT
    MrDT fapfap
    14 Jun 2002
    You am teh code daddeh! :rock:
