Notebooks Is there a better gaming laptop cooler?
Discussion in 'Hardware' started by LightingBird, 17 Apr 2011.
  1. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Technically you can, but you'd need some massively beafy fans, a lighter frame, an Arduino, a blutooth shield and some serious programming skill...
  2. Bungletron
    Bungletron Minimodder
    25 May 2010
    If they build it then I will buy it, I could also use it to strafe the cat, AMAZING!
  3. Bloody_Pete
    11 Aug 2008
    I know what to do next summer now... :p
  4. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    i have never bothered with these stands, but always stick a book/magazine on my lap then put my notebook ontop of that, helps stop roasted nuts and keeps the air flow to the fans.
  5. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    This is the one I've recommended to friends in the past. Large single fan with low RPM so quiet while shifting a ton of air and the size of it will likely be effective regardless of vent placement on the laptop chassis.
    It would have saved a lot of hassle if you had just said 'Why do you need to know what model it is? I am unsure of these things.' ;)
  6. bagman
    bagman Minimodder
    18 Apr 2009
  7. docodine
    docodine killed a guy once
    10 Feb 2007
    OP hasn't signed on since his last post here FYI
  8. LightingBird
    LightingBird Minimodder
    25 Feb 2004
    This thread is over a month old. I've just been readng.
  9. bagman
    bagman Minimodder
    18 Apr 2009
    oh I didn't know I just saw it on the list and thought I would add my 2 cents
  10. Throbbi
    10 Sep 2009
    :duh: Should know better than to not check dates. Bad throbbi, bad.
  11. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Okay so this thread is dead and all, but I'd still like to add a couple of things in case someone finds this via search.
    The Enermax cooler is darn good. Lovely build quality, low price and it actually works.
    The other thing I wanted to say was that laptop coolers are like desktop PC cases. If you have a rubbish stock CPU cooler the chances are your temperatres will be high even in a top-end air cooling case. There's only so much that can be done. If you have a decent laptop, one of these will mean low-noise gaming for hours without overheating. If you have a rubbish laptop it's not going to make much of a different at all.
  12. docodine
    10 Feb 2007
    Which gaming laptops have proper cooling?
