Small Form Factor Is there any point upgrading to 64bit AMD?
Discussion in 'Hardware' started by bertie, 14 Feb 2005.
  1. bertie
    bertie What's a Dremel?
    7 Nov 2003
    I currently have a 1700+ AXP at 3200+, a gig of ram, NF7-S etc - is there actually any benefit in upgrading to 64bit? The only reason I would do so at the moment is to go down the SFF route, looking particularly at the rather pricy SN95G5V2
    Should I wait til Nforce 4 comes out, or will that require me to sell my 6800GT and get a PCI-E one?
  2. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    In order to use Nforce 4 you MUST have a PCI Express video card. Otherwise, Nforce 3 is the way to be. Anyway, if you are looking for improved performance over inadequacies of your current system, then yes, it is worth upgrading. Otherwise, I would stick with what you have. But, if you need a SFF box, the SN95G and an Athlon 64 is definitely the route you'd want to take; the performance improvements over Athlon XPs is gigantic in some high end games.
  3. bertie
    7 Nov 2003
    What a wonderful reply - thanks for the useful advice. I think I will stick with what I have for now, until prices drop or there is another major leap in technology. I can't be bothered with PCI-E at the moment, it seems rather pointless if AGP is still not even being used to its full potential.
  4. RotoSequence
    6 Jan 2004
    All in a day's work ;)
  5. Firehed
    15 Feb 2004
    It's just futureproofing right now - you'd really be crazy to set up a new AGP system right now (with a new video card) since PCIE will be really in full swing by probably june-ish.
    That said a stronger CPU with an A64 setup could probably do a lot for you.
  6. RotoSequence
    6 Jan 2004
    Not with his overclocking and 6800 ;)
  7. Guest-16
    Guest-16 Guest
    Havent looked at shuttles for ages, but cant you get an nForce 3 250 based one? Still has AGP but you get a A64 socket too.
  8. Hiren
    Hiren mind control Moderator
    15 May 2002
    SN95G5V2 has all the features bindi mentioned.
  9. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I'm waiting for the 64bit Windows, once i see the performance figures i'll consider the jump :)
  10. Guest-16
    Guest-16 Guest
    *That's* the fo-shizzle, yo. I knew i wasnt mad.
  11. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    Please tell me you're not going to talk like that at the Manchester meet. :D :hehe:
  12. Hiren
    15 May 2002
    Of course he is didn't you know bindi is the bit-tech rude boy :D
  13. Guest-16
    Guest-16 Guest
    ****in hell yea mofo. In'it yo. *does horns with fingers*
    :blush: bwahaha
