Is there any way to controll a pc Via Palm Os and Bluetooth?
Discussion in 'Hardware' started by Wolfe, 6 Jan 2004.
  1. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Pretty Much what the title says.
    Is there any way to controll a pc/media player/anything else Via Palm Os and Bluetooth?
    I have a Tapwave Zodiac (www.Tapwave.com) That's got Bluetooth, and i plan to buy a bluetooth dongle, (for Web Browsing if nothing else) and want to use it for a remote.
    All the software i find seems to be for a Phone.
    Thanks.
  2. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    Any old VNC should work for you i think. Well, of course you need to find a VNC that is compatible with palm OS but shouldnt be too hard i would guess.
  3. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    IIRC you can get a version of VNC which will work on PC/PDA's however I think you can only use the PC to control the PDA not the PDA to control the PC. Atleast it was that way the last time I looked. I'm sure there is something out there that someone will dig up though :)
  4. Wolfe
    7 Sep 2003
    Sorry, i'm not really awake at the moment so
    VNC?
    Which is?
  5. Wolfe
    7 Sep 2003
    Bump
  6. fivecheebs
    19 Feb 2003
    VNC = Virtual Network Client.
    I searched google for VNC PALMOS and This Is Is the first entry. Then the site states this ... "PalmVNC supports remote access (view and control) to your Win95/NT or UNIX desktop via Inter-/Intranet. PalmVNC also allows you to collaborate with people in your office from your PalmPilot or PalmIII PDA" so within 5 seconds i found a possible proggy. Looks like this one does not support more moddern OS's tho but then i havent scrolled the page yet.
    Hope you enjoyed being spoon-fed :)
  7. Wolfe
    7 Sep 2003
    I never thought of something like that, whic lets you control anything with it. If you conld use that over the internet it would be SOOO cool. Control you home pc from anywhere with your palm (yes, I know you can do it with windows).
    Yum Yum
    Thanks
  8. Wolfe
    7 Sep 2003
