Is there enough market for another Waterblock?
Discussion in 'Modding' started by Fozzy, 9 Sep 2007.
Would you buy a watercooling blocks for $20 bucks a piece
  1. Yes if it was modular (future friendly)
    13 vote(s)
    19.7%
  2. Yes
    8 vote(s)
    12.1%
  3. No
    5 vote(s)
    7.6%
  4. Maybe if it looked good
    4 vote(s)
    6.1%
  5. Depends on the performance
    36 vote(s)
    54.5%
  1. radodrill
    radodrill Resident EI
    14 Mar 2006
    No kidding; put it this way, don't use Al as that will be a detriment if you're looking to gain part of the performance market.
  2. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    :yawn: just make a few models so we can see em.
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    or at least some sketchups
  4. radodrill
    14 Mar 2006
    Same thing; a sketchup is software specific, while a 3D model is the general term.
  5. The_Beast
    21 Apr 2007
    Supra55 said make a model not a (computer) 3d model, so I thought he meant a model made of wood or plastic
    I know I'm splitting hairs but I like to do that
  6. mattthegamer463
    26 Nov 2004
    Wouldn't that be a prototype then? I second that we need to see some prototypes so we can see if these blocks will match our case decor.
  7. radodrill
    14 Mar 2006
    In design work a model usually refers to 3D CAD and a physical representation would be a scale model (1:1 is a full scale model); if it's a test unit then it's a prototype.
  8. Supra55
    10 Oct 2006
    Ok, make a sketchup for the benefit of yourself and all of us, then make a wood or acrlyic model so we can see a more accurate interpretation of your idea.
  9. radodrill
    14 Mar 2006
    But what if he uses a different CAD package or solids modeling program? I can't make a Sketchup with Pro/E or Solidworks.
    Back on topic:
    Yeah; make a (3D) model and if possible a nice scale model or prototype so we can see what you have in mind.
  10. Supra55
    10 Oct 2006
    By sketchup I'm just using a medium commonly used I could care less what he uses to show us just make one.
  11. Teyber
    Teyber ******
    18 Mar 2007
    how will you make 1000? good luck with that. im interested though.
    o, needs good design, plus 100% leak proof(basically)
  12. Asulc
    Asulc Minimodder
    18 Jul 2007
    I would buy them if they were copper, looked good, and had good performance. Please let us know when this is a possibility. And defintially send one for review to bit-tech.
  13. Teyber
    Teyber ******
    18 Mar 2007
    whoa wait a effing minute
    koolance rads are aluminum? yes yes yes yes yes yes yes.....yes yes yes yes yes yes yes! finally! haha an all aluminum loop. There is a god! will be buying one kind soon hopefully :D
    and 1000 at 5$ cost would be an initial investment of 5,000$ not including mounting, et cetera. If you don't have cnc,(converted mini mill works fine), then cost of manual labor would be insane!
    but copper can be had for not crazy expensive. Id start out doing 10 or so, see how they perform.
    Reed
  14. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    There is a $20 block on the market, the older D-Tek Whitewater. However it has an aluminum top and doesn't come with a universal mounting plate.
    http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=106
    And aluminum is garbage compared to copper when it comes to watercooling.
    Unless you're doing all of the work yourself with equipment you have free access do I don't really see any way it would be possible to produce a block at such a price point. The smallest base you could possibly make and still have it sealed with an o-ring would be 2" x 2" x 3/16".
  15. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Nah, 2x2x1/8", o-ring captive in the top instead of the base.
    Agree perfectly on the other points though.
    And BTW, still nobody will make my design for less than a few hundred...
  16. eegg
    eegg What's a Dremel?
    29 Aug 2006
    i would only order one if you would actually test it out on a pross or on something else and show us the oc potencial of them
