Windows Is there neway of hooking my gamecube up 2 my pc monitor?
Discussion in 'Gaming' started by buglish, 22 May 2002.
  1. buglish
    buglish What's a Dremel?
    8 May 2002
  2. buglish
    8 May 2002
    ne1 got ne ideas at all???
  3. GJUK
    GJUK What's a Dremel?
    10 Apr 2002
    BUMP 4 u man
  4. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Dont bother with them cheap things from lik-sang as the only really good converters cost around £500 ;)
    What you could do is get a TV card and use a program called Dscaler, this is what I use. The quality isnt going to be as good as a TV but the text isnt blurry.
    EDIT: Or you could go exspensive and buy a new monitor with svideo on it, you can get CRT monitors with svideo but there rare and cost loads or you could get a LCD most desent makes have svideo inputs.
  5. buglish
    8 May 2002
    nice, cheers man, u got ne decent sites to get cheap tv cards? and where do i get the program Dscaler from? sorry if thats a dumb question :)
  6. Kevo
    9 Sep 2001
    TV cards dunno really try dabs the card I use is the PCTV Rave.
    And dscaler
  7. djgizmo
    djgizmo 1337 pimp
    26 Mar 2002
    i wouldn't bother!
    i love my Pc, and i already more games than i can bother to beat!
  8. buglish
    8 May 2002
    yeh but i wanted the gamecube in the same room as my pc, and i dont have a tv in here with me, so i wanted it to run through my monitor while i'm in here
  9. buglish
    8 May 2002
    Kevo, r u running a games console through pctv rave, i've encountered a problem and dunno wots up, first off, i get a picture from my gamecube, but it shudders a lot, also, wenever i exit the program, windows xp tells me i have encountered a serious error, and tells me whether to send it or not, ne1 got any ideas on wots up? help! :(
    p.s. i've tried re-installing, but no use:sigh:
  10. Kevo
    9 Sep 2001
    Im runnig mine thorugh a Rave. Have got the latest drivers for the PCTV Rave??
  11. buglish
    8 May 2002
    nope, just bought it a day ago, i cud post a screen shot of what it looks like?
    cud u post a link of where to find them please, cheers :)
  12. Shepps
    Shepps Slacking off since 1986..
    5 May 2002
    I got a PCTV Rave, i tried to use me N64 on it but the screen was fooked, will this dscaler make it work properly?:idea:
  13. Kevo
    9 Sep 2001
    You should be able to find the drivers here.
  14. buglish
    8 May 2002
    i got it working now, installed the driver, another problem was that it automatically switched into 60hz mode at the beggining so i changed it bak to 50, thanx 4 the replys, :)
  15. Kevo
    9 Sep 2001
    Glad you got it working!
