Graphics Is this 5870 referance pcb anyone?
Discussion in 'Hardware' started by thetrashcanman, 22 Feb 2011.
  1. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    Hi everyone, ok so I've just got hold of this xfx 5870 standard clocks and am desperately trying to work out if it has a custom pcb, have tried scouring the internet, looking for reviews or something of the same model, but it seems difficult to find, just wondering if anybody had a idea about it? Or where I might find some information that could help, many thanks in advanced :D
  2. faugusztin
    11 Aug 2008
  3. thetrashcanman
    18 Nov 2010
    thought it was a bit of a duh question, but needed to find out for certain as I'm ordering a waterblock for it, what do you think faugusztin? Looks standard to me :)
  4. faugusztin
    11 Aug 2008
    No, unfortunately it isn't. Again, look at power connectors, they are in different direction. Then you have some small changes visible even at back of the board (4 resistors in every line instead of 3) etc etc.
  5. faugusztin
    11 Aug 2008
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I have some pics of the standard PCB on my thread (in sig) and with a waterblock, so if you opened it up you'd be able to compare both, as the EK block I use doesn't go near the power connectors. If your lucky everything else is in the same place...
    The only way to be sure is by taking the heatsink off...
  7. thetrashcanman
    18 Nov 2010
    Which I plan to do tomorrow now :D, cheers for your help chaps :)
  8. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    i usually look for:
    "AMD" (or "NVIDIA") printed in the center of the PCIe connector, just above the pins.
    a black, solid steel heat spreader that covers the whole backside of the card.
    the "bat-mobile" cooler with a radial flow fan on the far end.
