Modding is this LCD gonna work?
Discussion in 'Modding' started by FL@MeS, 13 Feb 2002.
  1. FL@MeS
    FL@MeS What's a Dremel?
    4 Jan 2002
    again this **beast** crops up....
    i emailed 'em with some questions.... heres the reply (its pretty self-explanitary):
    "FAO Ben,
    Thank you for your email.
    Our Technical Department say that the displays use the Samsung KS0066 driver
    chip, which is similar to the HD44780 driver.
    Also the flexible cable is very thin and soldering is not recommended.
    Regards,
    Alison Brown
    Farnell
    Internal Sales Office
    Tel 0870 1200200
    Fax 0870 1200201
    mailto:sales@farnell.com
    website: www.farnell.com/uk"
    so would this work with LCD Center and stuff, and how would i soldier it?
    do you think is hud get the one from maplins? it seems easier....
    code: VX24B
    or
    code: RM88V
    soz about post size
  2. BlackFlux
    BlackFlux What's a Dremel?
    17 Jan 2002
    Dude I don't know too much about LCD's but the one from maplin looks like it might be a lot easier to hook up. :D
  3. FL@MeS
    4 Jan 2002
    thats what i thought, i have the exact tutorial for that -- it looks sturdy too.
    damn stock losss..........
  4. BlackFlux
    17 Jan 2002
    I mean they did say the flexible cable is very thin and soldering is not recommended. If I was you I would wait until I get a pros opinion. Some of the guys here a really hardcore when it comes to LCD's.
  5. Cheese
    Cheese Doc
    6 Oct 2001
    Don't buy the maplins ones... do not, I repeat do not buy the maplins ones. You want an easy life buy from MO, shipping is now $10 - you can get a 4x20 MO for almost the same price as the maplin unit - about £60 all in...
    And yes wiring one of those lil ones isn't quite as easy a normal parallel - and i wouldn't recomment you wire a parallel lcd unless you're confident at soldering. I've seen a fair few people waste a lot of money trying now...
    Cheers,
    r.
  6. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    Or if you ARE into soldering...get a 20x4 pre inverted, ready to wire to parrallel port, for about $30, inc shipping to uk :D
    Else I'd go with MO - they look good to me although i have no first hand experience
    Charlie
  7. FL@MeS
    4 Jan 2002
    i wanna do this on the cheap,
    and i have time -- which saves me money..... also i can ask ppl to do the soldiering for me, :D
