Is this motherboard worth it?
Discussion in 'Hardware' started by Dinh, 16 Dec 2005.
  1. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
    http://www.newegg.com/Product/Product.asp?Item=N82E16813157081
    The ASRock 939Dual-SATA2. The reason why I want this board is that :
    1. I just bought a BFG 6600GT AGP :duh: Bad Choice.
    2. I've decided to upgrade to 64bit.
    I've read so many reviews on this board, and some are good, and some are bad. I can't really decide what to get. :waah:
    Anyways, Is there a socket 939 motherboard that has both PCI-Express and AGP 8x on it?
  2. AWACS
    AWACS What's a Dremel?
    10 Jun 2005
    asrock are generally known as a cheap mobo manufacturer... though some are happy with their stuff and some aren't... it depends a lot more about what are you going to use it for... and belive it or not Asrock has a board with both pci-e and agp(the only manufacturer?)... but I've seen a few nice reviews about it... one coming from bit-tech (if memory server right)
  3. Supershanks
    Supershanks What's a Dremel?
    14 Mar 2005
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Its supposed to be a very good board. Theres a few members on here with it IIRC. :)
  5. AWACS
    10 Jun 2005
    I belive that is one of the best boards asrock has ever made... I know it swept us all down on the floor when it became public
  6. hitman012
    hitman012 Minimodder
    6 May 2005
    I've heard it recommended here a lot and seen good reviews... I'd go for it.
  7. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Yeah ive always had good luck with ASrock boards, mostly socket a tho. They overclock well and run rock solid. If I remeber correctly ASRock boards are made by ASUS, infact im almost sure of it.
    That looks like a nice board, too bad you have that agp card as the a8n-sli flies :D
  8. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    I have one. It's very good. That, and it has the ability to upgrade to M2 in the future.
  9. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    M2 in the future? Umm, no it doesnt :eyebrow:
  10. Dinh
    27 Jun 2004
    It has a expansion slot, which you have to buy the card for. Anyways, this is solid for gaming right? :D
  11. cysus
    cysus What's a Dremel?
    14 Apr 2004
    You're exactly right. ASRock is the name Asus puts on it's crazy/cheap lower-end stuff. Haven't heard many complaints about the quality, just the obvious limitations.
