Graphics is this particular card good?
Discussion in 'Hardware' started by bee2643, 28 Mar 2004.
  1. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    Asus v9570-TD GFX-5700 256MB DDR 8xAGP w/TV & DVI Retail
    its $245CAD at a local shop, and thats pretty much the most i can afford...how much of an upgrade would this be from a GeForce4 Ti4200 64MB?
    is it any good?
  2. orb
    orb satisfying.
    23 Dec 2003
    SAPPHIRE ATI RADEON 9800PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -BULK -OEM
    $211 at newegg.com :thumb:
  3. bee2643
    7 Mar 2002
    1/2 the ram?
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Only avaliable in 128mb and 256mb versions.
    I advise the 128mb. :D
  5. bee2643
    7 Mar 2002
    well that will still be just over $300 after shiping, which is what the local shop here sells them for also, but its too much for me lol
  6. unclean
    unclean SMP obsessive
    30 Dec 2003
    half the RAM makes no difference. the 9800 pro will cane the 5700... a LOT.
    it may have more RAM, but it will be much worse quality, and slower RAM. also, the bandwidth is also a limiting factor, the 5700 cant cope with 256mb, so it will only use about 128mb and the rest is basically a waste. the 256mb would be more suited and usefull on the 9800 pro.. but then it all gets expensive. save yourself some money and get a 9800pro. looksie at some benchmarks if you dont believe, the 9800pro is the top end card, where 5700 is nvidia's midrange card. 9800pro will own the 5700 for less money too it would appear.
  7. Monster63385
    Monster63385 What's a Dremel?
    18 Mar 2004
    Cards with 256MB are currently useless, if you look at benchmark scores for the 128MB and 256MB versions of the 9800pro they are almost identical. I'm not saying i wouldn't buy a card with 256MB, cus i am getting the 9800XT, i'm just saying that current games don't use all 256MB. I would also say get the 9800pro.
  8. bee2643
    7 Mar 2002
    ok thanks for all the input, much appreciated
    i just notice that when maps load in far cry and tribes2, my ram usage goes to about 80/90% and i have 1024MB
  9. Shadowed_fury
    21 Nov 2003
    Yes, farcry loves ram! :hehe:
  10. Shwang
    Shwang What's a Dremel?
    4 Jul 2003
    the 9800Pro weill be more expensive in Canada, and newegg doesn't ship internationally, at least they didn't 2 weeks ago. and it's $211USD. Cheapest 9800 Pro I've found that I'd reccomend, just dont' have the cash for for another while is the Sapphire 9800Pro at A-Power for $309 CAN. Shippin gisn't too bad and would run the price up to ~330, but as you said you can't afford that ATM, so I'd go with the 5700, it's a better card than the 5600 and you'll be happy with it, and it will be a definite improvement from the 64mb TI.
    You have to take into account that the newegg price is in USD which works out to $275 CAN but he can't even get that price because they don't ship.
    OT, just out of curiousity, how well does Farcry play with the TI4200?
  11. Shadowed_fury
    21 Nov 2003
    I can tell you it plays crap with a gf2. :hehe:
  12. bee2643
    7 Mar 2002
    i have all the graphics set to medium and it plays awesome, few skips
    at low, it looks allright, but absolutely no lag whatsoever
    high...well, i get about 2 or 3 fps
