Is this PSU good enough?
Discussion in 'Hardware' started by couzo, 25 Jun 2002.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    First of if this should go in the electronic forum please move it!!
    This is my system spec:
    XP2100+ Alpha 8045 with a Ys-tech fan
    Radeon 8500LE 280/280
    Soyo Dragon Ultra Platinum
    Ricoh CDRW
    LG 50x cdrom
    2x 30cm Cathodes
    2x 4.5 inch cathodes
    1x ccm baybus
    1x external power supply mod (with a glow pad on 12v)
    1x 40gb IBM Deskstar
    I am soone getting 2 7200rpm Mators to put in raid 0 (I know there won't be a major performance boost all you raid nuts out there!!)
    Will my enermax 350w PSU be ok with this or should I get a more powerful one if so which is the best to go for and where from?
    Thanks sorry this is soooooooo long!!
    Couzo
  2. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    an enermax 350 should do just fine with that setup...
  3. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    A 350 watt Enermax shoul be great for that setup. Do you have any other PCI cards or fans that could draw a lot of power though? Mind you, you should still have enough watts left over for most things anyway and the power regulation on the Enermax should easily be able to cope.
  4. couzo
    26 Apr 2002
    Yes I have 3 80mm fans and one 120mm fan
  5. jamiesurfs
    21 Oct 2001
    No worries really. Just looking at mine, I have a 350 watt Enermax with a fair amount of stuff and it's great, so you should be well ok!;)
  6. Vittorio
    Vittorio What's a Dremel?
    30 Apr 2002
    I am running a 400 Watt P/S and i am running the following off it with no problems:
    4 x HD's
    1 x CDRW
    1 x DVD
    3 x 80mm case fans
    1 x 8000 Rpm CPU fan
    12" Cold Cathode
    I have never had any power porblems, I am going to add a SCSI HD later this week too.
  7. couzo
    26 Apr 2002
    I am having a few problems with my enermax such as the comp is not sutting down properly and when I have a few things on one of the lines my hard rive powers down would getting a higher voltage psu make these problems go away??
  8. Vittorio
    30 Apr 2002
    When you say its not shutting down properly, do you mean it is not switching itself off?
    What version of windows are you running?
    Do you have any power saving options switched on in windows or in your bios?
  9. couzo
    26 Apr 2002
    Basically when windows XP shuts down it goes to the windows shutting down screen then freezes and I hear the hard drive turn off but the cathodes and fans stay on?? Then I have to hold the power button for 4 seconds then it all turns off. There is an option to have instant of or 4 second delay but on both settings the outcome is the same as the above???
