Modding is this xbox mod possible??
Discussion in 'Modding' started by STellY, 19 Dec 2003.
  1. STellY
    STellY What's a Dremel?
    24 Aug 2003
    ok lol i was messin with xbox live.... and the voice masks are freaking hilarious as a lot of you know...
    and god i just thought how awesome it would be to have those in a phone conversation... besides buying an actual voice changer... is there anyway this would be possible using xbox???
    lol, thanks
  2. death_star
    death_star What's a Dremel?
    14 Jul 2003
  3. Malvolio
    Malvolio .
    14 Dec 2003
    lol, quick answer, ok I've got a good xbox question for anybody who's ever tried this. Can you remove the hard drive in an xbox, use it in a computer, do a partition swap with another drive, and put the new partition swaped drive in place of the old one? I've tried this before, but my bios wouldn't boot with the xbox hdd :eyebrow:
  4. death_star
    14 Jul 2003
    No. Not without a modchip. :rock:
    Edit: Wont work on a computer anyway so...
  5. shred444
    shred444 What's a Dremel?
    16 Dec 2003
    how big is an xbox hd anway...never thought about checking mine.
  6. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    10 Gig I think
  7. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    8GB actually. More than enough for a console, easy for me to burn through in a few hours provided I have a good broadband connection. :D
  8. STellY
    24 Aug 2003
    the first revisions were 10 gb i believe and then they changed to 8gb seagates or vice versa.... atleast i think
  9. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    (1) yes xbox hard drive will work in a pc.
    (2) yes xbox hard drive can be upgraded to 200GB
    (3) No to the vioce convosation.
    (4) xbox needs a Mod chip to swap hard drives.
    For all other things including mods and case mod to the xbox visit
    XBOX-SCENE :rock:
  10. sirgeoph
    sirgeoph What's a Dremel?
    19 May 2003
    the voice thing could be done very easily and for like $1.... go to radioshack or somewhere like that and buy an adaptor that changes from the rca audio (red & white) jacks to phone (headphone) plug.. plug the audio cables from the xbox's av cables into the rca connectors on the adaptor and plug the phone plug from the adaptor on either your mic or line-in jack on your computers soundcard....you'll have this:
    XBOX AV_____ADAPTOR
    V.........................V
    R ======[¯¯]=O¯¯¯¯\_to sound card
    W======[__]=O____/¯
    now use a phone dialing program on yourcomputer... talk in whatever game elts you do the voice mask and the phone software will then use the xbox's audio as the audio it sends over the phone line.
  11. STellY
    24 Aug 2003
    lol every1 else says it couldnt work but imma try it neway :p
  12. Fatboy
    Fatboy Bored
    8 Oct 2001
    X-BOX uses some crazy ass modifeied filesystem , fat32x or something, thats why it dont work in a comp. The DVD is changeable as well i beleive.
  13. sirgeoph
    19 May 2003
    FatX
  14. Malvolio
    Malvolio .
    14 Dec 2003
    BTW, my bios sees the hdd in my xbox as 80gig. The actual drive is a western digital caviar "enhanced" IDE drive. It is a standard hdd.
  15. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    okay XBOX HDD WILL WORK IN PC!!
    How To Use Original Xbox Hdd In Your Pc (v0.3)
    Tutorial written by : GTac01
    First of all dl the hdd unlocker HERE
    Then connect your original hdd to your xbox, using Evox, get your hdd password. (in the evolutionx dash go 'system utils' then 'backup' , this will make a directory called "backup" on the C drive of your xbox. "hddinfo.txt" will contain the HD key)
    Once you have it, It looks like this:
    01:23:45:67:89:AB:CD:EF
    01:23:45:67:00:00:00:00
    00:00:00:00:00:00:00:00
    rewrite it as followed:
    0123456789ABCDEF0123456789ABCDEF01234567
    Yeah delete the last zeroes, and print it out, ull need it.
    Now you have to boot DOS (Bootdisk).
    Go here for a bootdisk that works with Win98-WinXp.
    Once downloaded execute it, enter a Floppy disk in ur computer.
    it will make that disk a boot disk.
    Then add the files: hdunlock.exe, hdunlock.pas, hddisabl.exe, and hdddisabl.pas to the bootdisk just created.
    Now, turn off your computer, set your xbox hdd to SLAVE, install your xbox hdd in your computer.
    Turn on your computer with bootdisk inserted, and it will ask you to press a key, then press a key, and you are in A:\>
    Type in hdunlock and press enter
    Select your xbox hdd, and enter your hdd password
    it should say DONE
    Type in hddisabl
    Select oyur xbox hdd, and enter your xbox hdd password
    it should say DONE.
    Congratulations you have unlocked your xbox hdd for formatting.
    Simple way to format it in WinXP:
    Now boot to windows
    enter "MMC" in RUN
    File-->Add/Remove Snap-in
    Click on ADD
    New window appears double click on Disk Management
    New window, click finish
    Click on OK
    Click on Disk Management(LOCAL)
    then right click on disk 1 and select the first option
    now right click on the right box next to the Disk 1 Box
    Then click on format, and format it the way you want it, select your partition letter and your ready to go.
    AND THERE YOU HAVE IT!
  16. Malvolio
    Malvolio .
    14 Dec 2003
    ok, now the question becomes, how do you get a normal hdd to work in an xbox without a mod? :p
  17. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    you use software exploits!
  18. Malvolio
    Malvolio .
    14 Dec 2003
    Welp, gosh darnit, that just explains everything ~sarcastic as hell~ :hehe:
  19. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    you need info more of it. go to ww.xbox-scene.com then to the tuts!
  20. Malvolio
    Malvolio .
    14 Dec 2003
    lol, thanks, I'm trying to downgrade the drive in my xbox, swap it with a 20 gig, I figure for the effort involved, it's worth it, because I don't have the cash to go out and buy a 80gig hdd, especaly one of that quality.
