Networks isolating two 2.4GHZ band wireless devices?
Discussion in 'Hardware' started by Draxin, 13 May 2004.
  1. Draxin
    Draxin Seeker of Photons
    29 Nov 2001
    at the coffee house i work at we have free wireless internet, provided by a 2.4Ghz linksys AP.
    we have had some problems with money going missing so the owners decided to install a small wirless video camara.
    well im the tech guy there so anything that goes wrong with anything they ask me to fix (no i dont get paid more for that)
    well it turns out that the video camara signal is washing out the wifi signal. the wifi however does introduce a good deal of fuzz into the picture of the camara.
    so we can use one or the other but not both.
    I was wondering if there is anyway to isolate the two devices so we can use both? or are we stuck witha wifi point and a useless camara, and need to get a different wireless camara?
  2. buzzy
    buzzy What's a Dremel?
    27 Dec 2003
    Sticking a boatload of concrete between the two will isolate the signals, but I suspect that might have an adverse effect on the coffee house ;)
    No other way AFAIK to isolate the signals - a wired camera would probably be the cheapest way out of this one.
  3. Draxin
    29 Nov 2001
    ok i was affraid that was going to be the answer.
    thanks anyway
  4. wharrad
    wharrad Minimodder
    26 Jul 2003
    you could try changing the wireless channel, I've read somewhere that this "can" sort out the problem with interferance from cordless phones on 2.4Gig
  5. Draxin
    29 Nov 2001
    we are currently running on chan. 6 would you recomend 11?
    if not what would you recomend?
  6. jake
    jake Network Gawd
    24 Jun 2002
    I have a similar problem with a wireless video sender and my wireless cards. Setting one device to be the lowest availible channel and the other on the highest [say 1 and 11 as these channels do not overlap] cuts out most of the interference but not all. Most of the channels in wireless all have some overlap with their neighbours so doing this keeps them as far apart as possible.
    You could get an access point that uses 802.11a as this uses the 5 GHz band and so wouldn't interfere but this would mean different network cards being required or you could try and get a camera that uses a different band.
    Alternatively you could install a wireless webcam type camera such as this one that actually uses the wireless network to transmit the video via IP and such would be working with, and not against, the wireless lan.
    J
  7. buzzy
    27 Dec 2003
    Just FYI - channels 1, 6, and 11 don't overlap each other. The channels between these do overlap, so you could try channel 1 and 11 just in case.
    Cheers
    Buzzy
  8. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    The best way, if possible, would be to change the wireless channel of the camera. So that the wireless connection remains the same.
