Other ISP choice?
Discussion in 'Software' started by Thatguy119, 1 Mar 2009.
  1. Thatguy119
    Thatguy119 Minimodder
    17 Nov 2008
    Hi, looking to get a new isp because tiscali's speed is abominable. Looking for somthing under 16 a month, good download speed, designed to be used for torrent and online gaming, and importantly EASY TO SET UP. Thats the main thing.
    What'ya got?
  2. SidRoberts
    SidRoberts What's a Dremel?
    7 Dec 2008
    I use Be There and it's absolutely amazing. Problem is, to get good speeds, you need to be near a BT exchange. I'm maybe 0.75 miles away from the exchange and I get about 18mbps for £17.50 a month. I've had it for a few months and never had any problems.
  3. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    +1 for Be*.
    £22 a month +BT line, am about 600feet away form the exchange so get ~20mbit down and ~2mbit up.
    I have rarely had any issues with there services since I moved to them ~7 months ago.
    To help you find out what ISP services are available in your area check out Sam Knows for a comprehensive list.
    Type in your post code, telephone number or exchange to find out detailed info.
  4. Thatguy119
    17 Nov 2008
    Im about1 mile from the exchange and it has o2 supported, for some reason be there says I dont have a BT line, which I do, I will call them and see what they say about that, if not I will go with o2
  5. Krikkit
    21 Jan 2003
    Ring BT and ask them what the situation is - it might just be that it's still registered with another phone company. You need to have a BT phone number to order it.
    +1 for O2/Be* though - I've got a static IP, flawless service and 22Mbps/1.7Mbps all for £17.50/month. :D
  6. Thatguy119
    17 Nov 2008
    Damn, its registired with tiscali, dont know if I can switch it without canceling my current broadband, which I dont want, annoyed indeed.
  7. dumde
    dumde What's a Dremel?
    28 Jan 2009
    Entanet partners do the best ADSL internet...
  8. Delphium
    18 Mar 2007
    Call Tiscalli and ask for a MAC code, then call Be*/O2 and explain you wish to migrate to them and give em the MAC code.
    This way there is a minimum of down time for the broadband, the switch over is pritty quick, often inside an hour.
    Unless you happen to mean that the phone line is Tiscali's and not BT's, in which case your either stuck with them or will have to move to BT :/
  9. Thatguy119
    17 Nov 2008
    No its bt's line, going with o2 premium, exactly what im looking for, thanks for the help all.
