Issues with SMP client
Discussion in 'bit-tech Folding Team' started by Combinho, 23 Jul 2009.
  1. Combinho
    Combinho Ten kinds of awesome
    5 Aug 2008
    I'm trying to get the SMP client up and running. Having installed MPICH successfully, I cannot get the client executable to run. The command prompt box just flashes and disappears, and when I try to run it from within the command prompt, nothing happens. Anyone got any suggestions?
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Have you run install.bat?
    Have you downloaded the new drop in binary from the website?
    Combinho likes this.
  3. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    My guess is you've got caught by the recent change of client. If you download the package called "Windows XP/2003/Vista/2008 SMP client console version" then the client you get when you unpack is the 6.23 version, which expired earlier this month, and unhelpfully, doesn't give any sort of error message.
    Once you have unpacked "Windows XP/2003/Vista/2008 SMP client console version" you need to download "Drop-in binary for current Windows SMP console client (6.24)" and drop it into the folder in place of the 6.23 client.
    HTH
    Christopher
  4. Combinho
    5 Aug 2008
    New drop in binary made it work. Thanks for the help.
