Overclocking It's enough?
Discussion in 'Hardware' started by Fares, 5 Feb 2009.
  1. Fares
    Fares What's a Dremel?
    7 Dec 2008
    Do you think that a 550W source is enough to overclock a GTX280?If yes how much?I`m also planning to ovreclock my CPU.Thak you.
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Easily.
    But what brand and model is it? A Bad 500W PSU might not be able to put out more than 300W.
  3. The_EXorcist
    The_EXorcist Possibly Australian
    14 Oct 2008
    You'll probably need more, if you want to push the CPU up alot. And i'd get a good Brand name PSU to match, at least 650w i'd say
  4. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    A full system spec would be useful to know, as you might be ok if you're only running the bare minimum of kit, however if you have 5 hard drives and a whole host of case fans, pci cards etc then you'll be pushing it. That does all depend on the quality of the 550W psu.
    I found the guide on here to graphics cards is good as it gives you the peak power seen when running the bare minimum set of components, so you can see if you're pushing the limit at stock speeds or whether you have Watts to spare.
  5. Fares
    7 Dec 2008
    Thanks for your help .If is it usefull my PSU brand is Deluxe.Sorry but I don`t know the model.:(
  6. mrbungle
    20 Sep 2004
    Sounds like a no name psu.
    Might not even run the 280 let alone clock lol
  7. tank_rider
    3 Feb 2005
    Have you checked to see that it has the right 6 pin and 8 pin pci-e connectors? If not then that's a pretty good indication it's not up to the job!
    A photo of the data sticker on the side of the psu will soon tell us whether it's good enough or not, try to get one of those (the sticker with all the voltages and amperages listed) and we'll give you a definitive answer.
  8. Fares
    7 Dec 2008
    [​IMG]............this is it.
  9. Fares
    7 Dec 2008
  10. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    Hell no, my older computer at full load (IntelBurnTest) outputs a wattage of 480W
    Spec:
    Q6600 @ 3.4GHz
    8800GT Stock
    4Gb @800MHz RAM
    X4 120mm 1200RPM fans 12V each
    OCZ GameXStream 650W PSU
  11. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    That system will NOT pulling 480W under load...as for the OP's system, get a new power supply, that seems to be a no-name box that won't support the card.
  12. Fares
    7 Dec 2008
    well.....do you guys think this PSU can`t even handle right a normal GTX 280
  13. DorkSterr
    29 Nov 2008
    Unless my Kill A Watt product is defective it is 480W to be more specific it's 476W.
  14. Dozer42
    Dozer42 What's a Dremel?
    22 Feb 2009
    Why spend tons of money on the graphics card, but then short change it on the power supply side?
    It's like putting crappy regular gas in a Ferrari.
    Stick a crowbar in that wallet and go with a solid, known good, name brand, beefy power supply.
    It's the foundation of your system, and you want a solid foundation.
    The bad part is down the road, if you start having intermittent problems, you'll always wonder if it's that cheap power supply or not.
  15. Fares
    7 Dec 2008
    Yes ......I understand.A few days before while i was playing a game i felt a strange smell of burn coming from the case.Now it is working fine ,but i think the source was causing that smell,so i will buy a new one next days.
    Any advice from you will be great.Thank you.
    P.S:Do you think that the cause of that strange smell maybe afected the graphic card or any part of the sistem?
  16. lamboman
    25 Jul 2006
    My bad, sorry, I read that as an 8600GT first time round.
  17. kassenz
    kassenz Obsessed with overclocking
    8 Mar 2009
  18. Fares
    7 Dec 2008
    Is it this source:Antec EarthWats 650W, good enough for what i`ve asked up?:rolleyes:
    Output
    VoltageRange
    MAXReg.Ripple & Noise
    +5V 25.0A ±5% 50
    +12V1 22.0A ±5% 120
    +12V2 22.0A ±5% 120
    +12V3 25.0A ±5% 120
    -12V 0.5A ±10% 120
    +5VSB 2.5A ±5% 50
    +3.3V 25.0A ±5% 50
  19. azrael-
    azrael- I'm special...
    18 May 2008
    Or you might want that Corsair HX520W or HX620W for optimal pleasure. :)
  20. morris8809
    morris8809 Minimodder
    30 Dec 2006
    +1 for the corsair 620HX :rock:
