Windows Its reformattin' time!
Discussion in 'Software' started by RotoSequence, 20 May 2004.
  1. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Im going to be reformatting the HDD on the main computer. The drive is 80 GB. Planned partitions:
    1. XP partition. Partition size: 4 GB. Purpose: To old Windows XP OS and updates.
    2. Linux partition. Partition size: 4 GB. Purpose: secondary OS for tinkering around :thumb:
    3. Applications partition. Partition size: 20 GB. Purpose: Storage of programs like Adobe Photoshop, 3D studio Max, Maya, etc.
    4. Media Partition. Partition size: remainder of HDD. Purpose: storage of games, music, movies, pictures, etc.
    Those are the plans. Any reccomendations would be appreciated :thumb: Thanks in advance :D
  2. simon w
    simon w What's a Dremel?
    3 Nov 2003
    IMO unless you're constantly installing/uninstalling applications, theres no need for a partition dedicated to applications.
    Install Windows first, then Linux so you're using grub/lilo as your boot loader.
    You light like to think about having a FAT32 partition for sharing files between Windows and Linux?
    Here's how I've partitioned my to 80GB drives:
    HDD1:
    10GB for windows and apps
    ~65GB for my documents, games (they frequently change), music and video encoding
    HDD2:
    5GB for Gentoo (linux)
    1GB FAT32 for sharing files between Windows and Linux
    ~70Gb for downloads, my documents backup, Windows page file
  3. kenco_uk
    28 Nov 2003
    Coo, an install of XP in 4GB? Could be interesting :)
    XP + apps = 25gb
    Media = 45gb
    Linux = 10gb
    That's how I'd do it, tbh.
  4. ajack
    ajack rox
    17 Apr 2003
    You don't really need 10gb for nix tbh, 5 should be sufficient [obviously dependent on the packages you install]
  5. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    Mines currently setup as,
    HDD1 80gb (8mb Cache) partitioned to 2x40GB - Windows + Apps/Games
    HDD 2 10gb - empty
    HDD 3 120gb (SATA) - Docs, photos, etc...
    although I'll be changing it shortly to:
    HDD1 - 10gb - Windows
    HDD2 - 80gb (8mb Cache) - Apps + Games
    HDD3 - 120gb (SATA) - Docs, photos, etc...
    and I'll be adding a 2nd SATA for a raid (0 or 1 haven't decided yet) setup at some point :naughty:
    I've found that apps **sometimes** run slightly faster if they're not on the same drive as windows.
  6. RotoSequence
    6 Jan 2004
    Actually, I am giving this quite a bit of thought. Considering that applications would need to be swapped when XP needs formatting, It would be more worthwile to make that into a single partition. The planned Linux partition is going to be six gigabytes, using Mandrake with a few applications, including GIMP. Revised partition plans:
    1. XP and Applications. Size: 30 GB
    2. Linux. Size: 6 GB
    3. Media (images and games) 44 GB
    So those are the plans. After school, I am going to start backing up files that need to be saved and such. Probably going to take me most of the afternoon to complete application re-installation and updating :sigh:
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I'd keep as many apps as possible on a non-Win partition. I've just re-formatted the C: partition to clean up a very bloated Win98SE.
    OK, I had to re-install the apps on D: to get the info back into registry, but a lot of customising was left undisturbed. :D
    It also makes de-fragging quicker, as the apps partition doesn't see much change.
  8. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    need a loonix swap partition too :)
    i have mine as:
    hdd1+2 (raid 0) = 20gig for windows +apps/games etc, rest for 'stuf'
    hdd 3+4 = both have 1 partition at maximum size, also full of 'stuff'
    linux lappy is
    512mb swap
    50mb (ish) boot partition
    rest as root
  9. Carlk
    Carlk What's a Dremel?
    10 May 2004
    Dont forget XP is greedy, needs atleat 8gig 2 breath!! will run like a dog with 1 leg!! :hip:
  10. RTT
    RTT #parp
    12 Mar 2001
    My XP partition is 4gb and it's fine. same setup on all my XP installs since whenever it was released! :cooldude:
