Apple iTunes and Win7 64 crap
Discussion in 'Software' started by TobyKing1982, 26 Apr 2011.
  1. TobyKing1982
    TobyKing1982 Minimodder
    23 Apr 2009
    I can't uninstall itunes or reinstall or whatever. I get a message saying "The folder 'Program Files' contains a invalid character"
    What should I do?
    Toby.
    Btw I need it for my pod.
  2. Deders
    Deders Modder
    14 Nov 2010
  3. TobyKing1982
    23 Apr 2009
    I know iTunes is very destructive but its a good and simple piece of software once succesfully installed.
  4. Deders
    Deders Modder
    14 Nov 2010
    Did the link shed any light?
  5. TobyKing1982
    23 Apr 2009
    Deders can you explain this in simple terms?
    problem solved.
    FYI - first tried installing 1.4.2_12 JRE to no avail, even did a re-boot after.
    Next un-installed JDK 1.1 and that did the trick.
    Boy that was painful!
    chris
  6. Deders
    Deders Modder
    14 Nov 2010
    Ok I think JDK stands for Java Development Kit, Not too sure about JRE but it might have something else to do with Java.
    It looks like some of the packages that the iTunes installer installs might need to be removed properly first, but I'm not putting iTunes anywhere near my comp to find out though.
    Have a look through your uninstall programs and see what might be relevant.
  7. TobyKing1982
    23 Apr 2009
    Nothing with java is installed on my computer according to control panel, although I know it is.
  8. Deders
    Deders Modder
    14 Nov 2010
    Hmm, on my comp it on the list as Java(TM) 6 Update 24.
    Can you download Java separately and see if the installer package with that allows you to uninstall/repair, or even re-install it?
  9. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    JRE - Java runtime environment. As an aside have you installed any patches or service packs? We (at work) have noticed a lot of perculiar things going on with w7 x64 in the past 2 weeks, but nothing common, I couldn't get programs running right
  10. TobyKing1982
    23 Apr 2009
    I managed to get it working by installing Windows Install clean-up utility and removing everything Apple.
  11. Deders
    Deders Modder
    14 Nov 2010
    Oh the irony:duh:
