Apple iTunes freezing PC on luanch
Discussion in 'Tech Support' started by tennisball, 19 Jul 2010.
  1. tennisball
    tennisball [Insert witty comment here]
    28 Jul 2009
    So, I went to start up iTunes about an hour ago, froze my PC, so I though it was just a one off and restarted. 2 minutes later and I try again, only to be greeted by another freeze.
    So, I go to try and reinstall it, after about 10 seconds of uninstalling, it freezes again.
    So I try and boot in safemode, freezes. :wallbash:
    I've googled around but can't seem to find anything, any ideas?
    Thanks
  2. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    No sorry but I can reccommend using SharePod to synch your music.
  3. c0rnzey
    c0rnzey New Member
    27 Apr 2009
    Are you using the latest version?
    If not download the latest installer file and run that and it may remove the old version using the new installer rather than using the old one which seems to have the issue.
    Not sure if this will work, but if you still haven't solved it, it's worth a try.
    Regards
  4. ModMonkey
    ModMonkey Size 11 Carbon footprint
    22 Sep 2003
    I think this is normal Itunes behaviour??
    You could try uninstalling using the msiexec command.
    Go to the registry key in HKLM\Software\Microsoft\Windows\Current Version\Uninstall
    flick through the various keys until you find one that refers to itunes and copy the contents of the uninstallstring key. Paste that into you run command and if necessary replace the /I switch with /X. You can add /passive at the end if yopu want a progress bar but no prompts.
    To be honest that just runs the exact same thing as your add remove programs gui but you never know.
  5. tennisball
    28 Jul 2009
    Well, it's happening with other programs now, just tried to launch Fallout 3, didn't like that.
    Also happening when I press the Print Screen button.
    This is starting to get annoying now, might have to reformat.
    Any other suggestions?
  6. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Might want to check basic stuff like temps and run a full virus/malware scan if you're getting freezes across the board.
  7. c0rnzey
    c0rnzey New Member
    27 Apr 2009
    Have you changed any hardware or drivers recently?
    If so try reverting to any previous versions as this may be causing an issue.
  8. tennisball
    28 Jul 2009
    AVG runs a full scan at 4 O'clock everyday, just did a spyware check and found nothing.
    @C0rnzey: That's the weird thing, I've not installed ANYTHING new, nevermind drivers or hardware.
  9. hodgy100
    hodgy100 New Member
    2 Jun 2008
  10. tennisball
    28 Jul 2009
    Just did this, can't find any hard disks, maybe mine doesn't support SMART? (Samsung F3)
  11. c0rnzey
    c0rnzey New Member
    27 Apr 2009
    If you think it could be your hard drive try the Seatools hard drive diagnostic.
    Seatools
    You can either use a Windows version or a bootable DOS version.
    Hope this helps.
  12. Sterkenburg
    Sterkenburg To mod or not to mod...
    2 Oct 2005
    It definitely sounds like either an OS issue or a hardware issue. I'm pretty sure the F3 works with SpeedFan, but your motherboard could be the issue there. Whether your hardware is dying or not - you should make backups!
