Apple iTunes help
Discussion in 'Software' started by Carper, 3 Aug 2011.
  1. Carper
    Carper Guru
    19 Aug 2009
    Hey, basically i have itunes 10.4 installed on my computer and it seems to work fine untill i plug my iphone 3g in. Itunes doesn't recognize the device yet my computer does as it comes up with different programs i can open it in. I have uninstalled itunes and reinstalled it and nothing has changed, as you can imagine its very annnoying as i cant sync new songs ect. Any help would be great. Thanks
  2. longweight
    7 May 2011
    Is it a jailbroken handset?
  3. kol
    kol What's a Dremel?
    31 May 2011
    if the phone has a lock code to unlock it, punch in the code, leave it on the home screen then plug it in. might solve it
  4. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    Are you running windows 7?
  5. Carper
    Carper Guru
    19 Aug 2009
    phone isnt jailbroken just like it was when it left the shop. And yes 64bit windows 7
  6. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Have you removed any registry settings to do with Itunes ? There could be something lurking about thats preventing it from allowing your iphone to sync, or an easier option try it on another system with the same OS to see if it works perfectly on that..?
  7. thelaw
    10 Sep 2010
    Its likely windows 7/itunes not liking each other much which is known, i have a sync issue with itunes on my rig even after a fresh format/install of windows and itunes a month back...its never worked ok with me.....sometimes it syncs...sometimes it locks up and freezes itunes up...itunes have meant to have released patches to solve it but the problem persists....however if i plug the phone into my laptop with win xp there is no issue.
    I think the syncing program is bonjour in your programs list, if you un-install apple make sure you un-install bonjour as well and then download itunes again making sure you get the win 7 64 bit edition of apple itunes....see if that works...but i have done that numerous times but the problem still persists with mine...so i just use the laptop as the issue is with itunes itself and its crappy developers still not sorting out the issue with win 7 compatibility not the pc..
  8. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    i have no issues with the 2 iphones we have here iphone4 and iphone3g, on win 7, works every time, so i would say more likely a driver issue of some sort (USB/chipset)
  9. Carper
    Carper Guru
    19 Aug 2009
    Microsoft Windows 7 x64 Home Premium Edition Service Pack 1 (Build 7601)
    MICRO-STAR INTERNATIONAL CO.,LTD MS-7583
    iTunes 10.4.0.80
    QuickTime 7.6.9
    FairPlay 1.12.20
    Apple Application Support 1.5.2
    iPod Updater Library 10.0d2
    CD Driver 2.2.0.1
    CD Driver DLL 2.1.1.1
    Apple Mobile Device 3.4.1.2
    Apple Mobile Device Driver 1.57.0.0
    Bonjour 3.0.0.2
    Gracenote SDK 1.9.1.485
    Gracenote MusicID 1.9.1.102
    Gracenote Submit 1.9.1.133
    Gracenote DSP 1.9.1.43
    iTunes Serial Number -
    Current user is not an administrator.
    The current local date and time is 2011-08-03 20:58:09.
    iTunes is not running in safe mode.
    WebKit accelerated compositing is enabled.
    HDCP is supported.
    Core Media is supported.
    Video Display Information
    ATI Technologies Inc., ATI Radeon HD 5800 Series
    ATI Technologies Inc., ATI Radeon HD 4300/4500 Series
    **** External Plug-ins Information ****
    No external plug-ins installed.
    iPodService 10.4.0.80 (x64) is currently running.
    iTunesHelper is currently not running.
    Apple Mobile Device service 3.3.0.0 is currently running.
    **** Device Sync Tests ****
    One or more sync tests failed.
    Just done a test within itunes and got that back. As you can see the device sync test failed. Can you post one of these of your working one so i can see if there the same? Thanks
  10. RichCreedy
    24 Apr 2009
    Microsoft Windows 7 x64 Business Edition Service Pack 1 (Build 7601)
    Acer Aspire 7738
    iTunes 10.4.0.80
    QuickTime 7.6.9
    FairPlay 1.12.20
    CD Driver 2.2.0.1
    Bonjour 3.0.0.2 (333.2)
    iTunes Serial Number: blanked
    The current local date and time is 2011-08-03 21:08:04.
    HDCP is supported.
    NVIDIA, NVIDIA GeForce GT 240M
    **** Device Connectivity Tests ****
    iTunesHelper 10.4.0.80 is currently running.
    Universal Serial Bus Controllers:
    Intel(R) ICH9 Family USB Universal Host Controller - 2934. Device is working properly.
    Intel(R) ICH9 Family USB Universal Host Controller - 2935. Device is working properly.
    Intel(R) ICH9 Family USB Universal Host Controller - 2936. Device is working properly.
    Intel(R) ICH9 Family USB Universal Host Controller - 2937. Device is working properly.
    Intel(R) ICH9 Family USB Universal Host Controller - 2938. Device is working properly.
    Intel(R) ICH9 Family USB Universal Host Controller - 2939. Device is working properly.
    Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A. Device is working properly.
    Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C. Device is working properly.
    No FireWire (IEEE 1394) Host Controller found.
    Connected Device Information:
    Rich’s iPhone, iPhone 4 (GSM) running firmware version 4.3.5
    Serial Number: blanked for security reasons
    Sync tests completed successfully.
  11. RichCreedy
    24 Apr 2009
    did you manage to sort your problem?
  12. thelaw
    10 Sep 2010
    Everytime i see you post mate i look at your avatar and picture you pondering over your response in that exact same pose before you reply.:hehe::hehe:
  13. RichCreedy
    24 Apr 2009
    thats my zoidberg impression :p
  14. Carper
    Carper Guru
    19 Aug 2009
    installed a few things and basically copied what you had on itunes and it seems to have worked. Just plugged my iphone in and it synced :D Thanks everyone for the help and hopefully it continues to work
