Motherboards ITX Anonymous Club
Discussion in 'Hardware' started by Arboreal, 11 Jun 2016.
  1. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    Bloomin’ fanbois :rollingeyes: :thumb:
  2. Goatee
    Goatee Multimodder
    19 Apr 2015
    My new B560 case is taking shape. It’s still waiting a panel or two to come back from anodising but it looks good!
    David, Omnislip, BeauchN and 2 others like this.
  3. Arboreal
    21 Jan 2011
    Looking good, @Goatee!
    It'd be interesting to know about anodising costs, if you're happy to share that with us.
  4. Goatee
    Goatee Multimodder
    19 Apr 2015
    Thats the official one I ordered (so still in China), not my prototype.
  5. Arboreal
    21 Jan 2011
    Order 2 official Big 560s?
    Not me, I just DIY & go!
    Ahhh yes, the "Ooops we done them all silver, not black" anodising :lol:
    2 sets of UK cut panels ordered, should be a couple of weeks.
    I'm looking at powder coating, to see how that works out
    BeauchN and Goatee like this.
  6. David
    7 Apr 2009
    How much does powder coating add to the panel thickness? Just wondering if it'd be enough to cause issues sliding the side panels into place.
  7. Goatee
    Goatee Multimodder
    19 Apr 2015
    Hydro-dipping? Obviously with hydro sheets not rattle cans....
  8. Arboreal
    21 Jan 2011
    I haven't spoken to any local coaters yet, but 50 microns is a typical powder coat thickness = 0.05 mm With 1.6mm alu sheet we have up to 0.4mm wiggle room to fit it in the extrusion slot.
    Basically, thin paint or powder coat with be 1/10 of the max thickness.
    We may need to put tape down the insides to stop it rattling...?
    Hydro dipping may be tricky with all those holes to punch out of the film
  9. David
    7 Apr 2009
    Yeah, thinking about teflon strips / tape
  10. Vault-Tec
    30 Aug 2015
    With powder it all depends on how they do it. If they use a primer? it will be thicker. That said I can't see an alu case rusting so I doubt they would do that. There's a PC company on the IOW because Tom Logan uses it.
    David likes this.
  11. Goatee
    Goatee Multimodder
    19 Apr 2015
    50 on the front, 50 on the back and both front and back of corner post channels coated means you have 0.2mm left?
    or are you going to mask the channels?
  12. Arboreal
    21 Jan 2011
    Good point there...panels having 2 sides :idea:
    BUT I shall not be coating the channels, as I intend to experiment with different sets of panels and finished for a while.
    So, they will be left as supplied for the time being.
    I may still want to shorten the whole thing as I won't be putting a rad up top, but won't know how I feel about the size and proportions until I have built the standard one.
  13. David
    7 Apr 2009
    Tried the island based powder coaters several times this afternoon - no pickup, no answerphone. Hmph.
  14. Vault-Tec
    30 Aug 2015
    Well it is poet's day today...
    Piss off early tomorrow's Saturday.
  15. Parge
    16 Jul 2010
    God I'd forgotten about him and how much I dislike him.
  16. David
    7 Apr 2009
    Spoke to the local the powder coating firm, and job looks like it falls under their minimum order charge of £36.95.
    No idea if that's a good or bad price for coating, but it doesn't seem too bad for a one off expense.
    Arboreal likes this.
  17. Arboreal
    21 Jan 2011
    OK, that sets a start point £37.
    Did you send them the plans or quote a rough area of metal to be coated?
  18. David
    7 Apr 2009
    Just a rough area, and no additional prep.
  19. Vault-Tec
    30 Aug 2015
    That's pretty cheap. I've paid up to £100 for a BMX frame.
    The paint would cost you a tenner, then all the mess etc.
  20. David
    7 Apr 2009
    4 litres of omgitssocute!!
    LP GTX 1650, H77 itx board and an i3 as a placeholder for my misplaced 3770T.
    Goatee and Vault-Tec like this.
