Ahhh yes, the brass inserts that needed melting in... hope that goes well. I think I have a spare Be Quiet 300W SFX PSU here from that H170i rig, I know there's an old low power one that I wouldn't offer at this late date
Put up a build log here: https://forums.bit-tech.net/index.php?threads/3d-printed-mini-itx-nas-build-log.387792/ They were nowhere near as bad as I thought they'd be, tbh! I'll likely be putting up a marketplace thread when it comes time to get the PSU, because I want a few SATA SSDs as well. Plus I need to source a suitable power switch, an HBA, there's one panel I forgot to print, I still have a couple of magets to glue in place, I need to decide what to do about the logo insert, and I really should look at adding some kind of dust filtration. So... suffice to say I'm in no rush!
OK, not ITX, but very smol. I wanted a really small light gaming rig that doesn't compromise too much on cooling - I've been down the rabbit hole with ~ 1L mini PCs and LP single slot GPUs and, frankly, none have really impressed me. Most are hot, noisy and throttle a lot and the ones that don't are a little bit too weak. Now, strangely, I've settled on the idea that I don't want too much power, or I just stick more and more games on the smol box and hardly use my main rig. I only really want this for light gaming and to serve as my World of Warships rig. With that in mind, I bought a Dell Precision 3260 and got a deal on a 12GB RTX A2000. The card is a tight fit - it only just fits within the confines of the closed chassis - and I will have to heavily modify the LP bracket to secure the card properly and do away with the silicone foam blocks hamming it up is GPU supports. The only thing I am missing is the LP bracket - this card only came with a full height bracket, but the funky supports are doing ok while I await a new bracket from China. I could've stuck with a 6GB A2000 but this was only about £70 more than the average price for a 6GB card. It has a decent fan and I can't hear it at idle, despite it being locked to 30% minimum speed. The 3260 came a bunch of added value - an additional USB C module, SATA adapter and the PCIE riser, as well as a genuine Dell 240W PSU (despite the seller stating it was 180W). It has a i5 12500 (I am resisting the urge to slot in a 12700T) and 16GB DDR5 (which is enough for this PC) and a couple of m.2 slots. In order to use the rear USB C module with the A2000, I had to shave down the mount from this: PXL_20250703_214904082 by David posted 3 Jul 2025 at 22:59 to this: Shaved by David posted 7 Jul 2025 at 20:25 ...and I've had to forgo the 2.5" SATA caddy, but I can fit a SATA SSD in there and, because the A2000 has a blower cooler, I don't have to worry about heat. I still need to print a small support for the SSD. SSD by David posted 7 Jul 2025 at 20:25 ..add despite it's close proximity, It doesn't even seem to impede airflow to the GPU fan. So this little beast is currently hosting around 10TB of storage. A 1 litre PC, or even my MS-A1 are just a little too graphically compromised to run my chosen games at 1440p. This rig is not really that much bigger at 2.4L and I can still throw it in a backpack and have just enough grunt for my needs. Calling it a win.
That is super small, great bit of cramming and getting a scorching deal on a 12GB A2000. Adding in the brick volume probably makes it as big as the 3.25 L hybrid case I have my eye on for my 4060LP He's just down a white version too...
Yeah, but the 1.8 litre MS-A1 has a brick half it's size, as does the P350 Tiny, so it doesn't seem like a big deal. I need to see this case though. Not that I'm looking to buy one or anything. Just, you know, for science.
It’s on SFFN and Reddit, usefully for you it uses a 250W Hdplex GaN PSU. Latest post showing the white version.
My low profile bracket for the A2000 arrived, looking like this: B4 by David posted 10 Jul 2025 at 20:27 A half hour after receiving it, it looked like this: PXL_20250710_191027056 by David posted 10 Jul 2025 at 20:44 Now it fits. Back by David posted 10 Jul 2025 at 20:42
Nice bit of surgery there David. A powerful little beast. In other news, I'll be off at the weekend to pick up an unusual i3 9100 Q370 ITX combo
Saw that this morning. Interesting to note they're subbing out the manufacturing to make it affordable. I'm interested but not that keen on console style cases generally. The vertical sandwich style 7.5L T40 doing LAN duty currently works well for me. Something similar with a higher quality finish and space for a 120mm fan would be great. I chose it as it's about the smallest case that takes a decent GPU < 200mm and SFX/L power supplies The S5 should be able to pack a lot of horsepower in it's sub 10L design. I hope it sells well, surprised to hear the grey is so hard to get right at the required quality, with a 90% rejection rate...
What's the noise level like on Dell optiplex SFF and the Ultra SFF? I don't mind a constant hush,whoosh noise but a high pitched hiss or whine when the temps ramp up would drive me nuts.
You do have to temper your expectations a bit with the TinyMiniMicro 1 litre style machines - they do use socketed desktop processors and rely on a very slim cooling system. The upside over the more efficient models using mobile chips is that some models have a PCIE slot for further expandability; which brings it's own challenges from a cooling and noise standpoint. I've played with several and they are audible with under load, and the small fans do get whiny when worked hard. Personally, I've settled on something around 2.5 L which affords slightly larger CPU fans and a dual slot blower style SFF GPU. It's still audible but much more well mannered. If you want a true desktop gaming experience in a uSFF rig, with very manageable noise levels, you're looking closer to 4 litres with something like a 4060 LP or newer. However, that will attract the ITX tax - higher priced mobos, more specialised CPU coolers and SFF GPUs at a premium compared to a standard desktop counterpart. TBF though, the 4060 and 5060 models only really shine in the uSFF format, and even that is due to the dearth of other options.
NFC have just dropped this video of a 6L fully 3D printed case. Maybe a bit too big for you @Byron C ? 4060/5060 LP with Flex PSU
The biggest problem with that is the build volume. It looks like the outer case prints as one piece, and it only just seems to fit on a 270x270 build plate. That’s probably just outside of most people’s 3D printer build plate area - certainly outside of mine. I’ll grab the STLs when I’m properly awake and chuck them in the slicer.
I think they're only available to NFC patrons at the moment. This is what Josh said in his mail out this morning: "I'm doing something CRAZY and I am uploading the STEP files here, so you have the ability to modify the 3DLP for your own personal builds! I do consider this an official NFC product, so while I’m excited to share it with the community, I’m asking that you please keep the files private. This is meant as a special perk for supporters, and I’m hoping that folks who don’t have 3D printers—or who want the benefit of our optimized slicing, logo creation, or future revisions—will consider ordering one directly from NFC." I'm currently on holiday in a time zone an hour behind the UK, an unusual situation. More used to being an hour ahead in European time when away.
Ahhh. The description mentioned STL files with a link, so I assumed they’d at least be accessible somewhere. I’ll still take a look into it later, but I have a feeling it’s a little too big for most people to print.
The outer shell does look like a big file to print in one go. He did say it could warp if not well ventilated. I see that I did post a link a couple of months ago in this very thread to that 3.25L case
Asrock has soured me on ITX, for the moment at least. Check this out: Dual TB4 ports and three m.2 slots - Pretty epic feature set. Thing is, I'm on my second RMA and this one has been catastrophic - I initially thought I'd fallen victim to the Windows update killing m.2 drives when I lost a 2TB drive and then my 9070 XT dies. I only realised it was the board at fault after it stopped seeing m.2 drives in the other ports and then treating my spare GPU as a basic display adapter. The whole PCIE system is borked. Anyway, it's gone - Amazon couldn't offer me a replacement, just a full refund of £355 (yeah the ITX tax is really beginning to sting these days) and I saw a mATX Asus Z790 board for £130 on Amazon resale (formerly Amazon Warehouse) - a nice £225 saving so I can replace my dead m.2 drive. So, that's it - I'm busting out the Sama IM01 chassis again, because it can (just) accommodate full fat mATX boards. Yeah, it lacks the twin TB4 ports but you can buy an TB4 cards for ~£50 and it has more PCIE expansion options anyway. I still have my Dell Precision 3260 smol rig for WoWs and general browsing/light gaming but my big rig is going to be, well, bigger.
That's a real mare Dave, are your other M.2 drives and GPUs ok? I was watching Antony's (Combatus) MSI X870 review yesterday and wincing at the over £400 price tag... If you're going to pay premium plus money it's not unreasonable to expect the board to have premium abilities, let alone function properly! I'm staying well behind the curve and happy with used kit. Hope the Z790M works well
