Motherboards ITX Anonymous Club
Discussion in 'Hardware' started by Arboreal, 11 Jun 2016.
  1. David
    7 Apr 2009
    Bah, can't boot from an SSD in the wifi slot. I can see the drive and use it, but the BIOS can't see it as a boot drive. Thought, maybe enabling network boot options might do it but still no joy.
    So... I might be dumb enough to order a 2TB 2242 SSD after all. :lol:
    BeauchN likes this.
  2. Ice Tea
    Ice Tea Multimodder
    26 Jul 2009
    I wrongly thought the Minisforum UM790 Pro would be your thing, I guess it's a bit too small and bespoke.
    Arboreal likes this.
  3. Arboreal
    21 Jan 2011
    La la la, I'm not listening...!
    Byron C, MLyons and Ice Tea like this.
  4. Ice Tea
    Ice Tea Multimodder
    26 Jul 2009
    :D
  5. Ice Tea
    Ice Tea Multimodder
    26 Jul 2009
    One of the things that puts me off the tiny mini pcs is that you have to take the entire thing apart to clean the fan.
    I wonder why they didn't put a removable lid on top?
    pete* likes this.
  6. pete*
    pete* Just. Useless.
    29 Apr 2009
    I... think I know the problem. But, not sure what the solution would be... :duh:
    Posting in here because of you knowledgeable ITX addicts... and another question.
    Just put together the bits i've received from various places.
    The lil' PC won't boot with everything plugged in. The power button light turns on, but goes off
    as does the green light on the power brick. I thought maybe power brick is ****/broken,
    but after unplugging the GPU and the SSD's (x2) - it spins up the CPU fan. And stays on green
    on the brick. 330W.
    Quick check of the PC PSU Calc... and 499W it comes up as needing... :wallbash::waah:
    The power is from a HDPlex 400W DC-ATX.
    What are my options, other than taking away bits. I need the 2 SSDs, and I mean, the GPU is small I don't have
    another. And obviously there is absolutely zero space for any bigger PSU.
    It's (trying to) running Intel 4690K
    Gigabyte 4060LP
    16GB DDR3
    2 SSDs (500gb-1tb)
    And on top of that - love the case, so nice and small... but.. I can't get any fans in. At all. :lol: So, not sure
    how I can fix that, other than a larger case. But it is so nice. Proper struggle to get cables sorted.
    Cry at the pictures.
    If anyone has suggestions... that.. don't cost money... :hehe:
    [​IMG][​IMG]
  7. David
    7 Apr 2009
    I can't see that system pulling more than 250W, ever. More likely closer to 200W under normal gaming use.
    4060LP is 115W max and you can shave 20W off that easily with UV. The CPU will pull ~120W when maxed out. I don't see why the HDPlex and 330W brick wouldn't power it.
    Can you test the GPU in another system?
    I might still have a 1150 ITX board in my spares, if it'll help with diagnosing.
  8. pete*
    29 Apr 2009
    I could test it with same system but diff power supply - the whole system other than GPU and PSU
    was working in the other case.
    Just swapped cases. Will see what I can do.
  9. pete*
    29 Apr 2009
    Swapped PSU, starts up on the CS750m
    With SSDs/GPU connected. :oldconfused:
    In my simple mind, that says either the brick or the hdplex aren't
    providing enough juice?
    Just had this psu plugged into a wall reader, shows as below.
    [​IMG]​
  10. David
    7 Apr 2009
    Stress the GPU and CPU simultaneously and check the power draw
  11. pete*
    29 Apr 2009
    Tried plex/brick again, and it doesn't start again.
    The meter shows this (the jump is me trying to start it) - then nothing.
    I'll try the stress in a sec -_- … as much as I can anyway.
    It has no internet ability and only Lego games on it :hehe:
    Not sure if a quick stress prog anyway I’ve never done one ;D
  12. David
    7 Apr 2009
    CPU-Z has a bench tab that can stress the CPU. Just use Furmark for the GPU
  13. pete*
    29 Apr 2009
    I mean I just ran two games the most stressing it will ever get and it didn’t go over 125W according to wall. Sits around 99-105.
  14. pete*
    29 Apr 2009
    Just stressed with CPUZ and Furmark at the same time, meter never goes above 201.
  15. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    Have you tried it with the 400W AC-DC unit, rather than the external brick, as a test? That might confirm whether it’s the brick or the DC-ATX unit, given it’s working with the regular PSU.
  16. pete*
    29 Apr 2009
    I was going to try that next. But can’t find instructions on its use online and don’t want to blow them up :hehe:
  17. pete*
    29 Apr 2009
  18. David
    7 Apr 2009
    Are you using a generic 8pin PCIE cable or the one for the HDPlex?
    HDPlex changed the PCIE pinout on the DC-ATX between revisions - completely reversing the pos and neg feeds, which could be catastrophic for the unit and/or the GPU.
    How do I know this?
    I later found and compared the diagrams of the different revisions and saw the reversal.
  19. pete*
    29 Apr 2009
    Using the one from the HDPlex…
    Got nephew over so not able to keep checking right now. :duh:
    I did notice when I unplugged after it smoked one
    connector has one pin missing, with two cables going to one port and the other side has them all individual?
    [​IMG][​IMG]
  20. pete*
    29 Apr 2009
    So just powered up the system with the CS750M again. Doing a quick bench on the GPU see if
    It shows any issues but it has all booted up fine.
    So not sure where to go from here, it can’t run on
    the Corsair as it is massive, and the Plex I’m too
    worried it’ll burn out again or something.. if it even works now. Is there a way to test it and see
    what it is doing without plugging into a mobo/etc and blowing them up in the process? :hehe:
