Motherboards ITX Anonymous Club
Discussion in 'Hardware' started by Arboreal, 11 Jun 2016.
  1. M_D_K
    M_D_K Modder
    3 Apr 2002
    Chuck me a PM, if you have the DXF/STEP files that'll help alot :), also let me know what you want it out of, I do have a CO2 laser as well so can make 3mm Acrylic panels, or if you want metal I can zip em out of 3mm I've got alu, steel, stainless in stock at the moment, I have a couple sheets of grained and polished stainless as well.
    Byron C, pete* and Arboreal like this.
  2. David
    7 Apr 2009
    20mm?!?
    Talk? No, I expect you to die, Mr Bond.
  3. Cheapskate
    13 May 2007
    Beat me to it. Laser cutting capacity shouldn't be measured in mm, but in Sean Connery units.
    Arboreal, pete*, IanW and 1 other person like this.
  4. Arboreal
    21 Jan 2011
    Thank you, I do have all 6 faces in DXF form, but would like to redesign at least one of them.
    I'll PM you later when I have them lined up, as I disagree with the naming convention! They're calling the top & bottom panels 'sides' IIRC
    Outstanding!
    Can we define the SI Connery Unitsh please?
    David likes this.
  5. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    This sounds like a job for the Reg Standards Bureau if ever I’ve heard one. Once it’s added to the online unit converter, we’re all good.
    Though we already have a number of very well established units for length: the linguine, the double-decker bus, the brontosaurus, the Devon fatberg, the Osman, and the giraffe. Perhaps it might be a better fit for velocity? That currently only has the maximum velocity of a sheep in a vacuum as its base unit.
    pete*, IanW and David like this.
  6. Arboreal
    21 Jan 2011
    Best derail in ages thanks @Byron C!
    I do remember being schooled early on in science classes about appropriate units.
    The teacher saying that there weren't many things whose speed could be usefully measured in furlongs per fortnight ;).
    In other SFF news, I have just discovered via a YT vid about modular OPS tiny PCs that go in displays. More importantly, they can make nice 10" rack components.
    It's on the latest Hardware Haven IIRC
    pete* likes this.
  7. M_D_K
    M_D_K Modder
    3 Apr 2002
    Also let me know if you want any standoffs or fittings in it can do most PEM fittings if you go on there site like standoffs or clinch nuts etc...
    David and Arboreal like this.
  8. M_D_K
    M_D_K Modder
    3 Apr 2002
    How many Sean Connery's make up 12kw lol
  9. Arboreal
    21 Jan 2011
    Standoffs & fittings too? No way!
    That's the mobo mounting sorted then :D
    M_D_K and pete* like this.
