Case Mod - In Progress ITX Silverstone sugo05 mod
Discussion in 'Project Logs' started by Kviker, 28 Jan 2011.
  1. Kviker
    Kviker Member
    22 Jan 2010
    Hi! I started my new build.
    Spec:
    -Zotac H55-A-E
    -Core i3-530 box
    -2gb ram
    -Palit 470 GTX 1280 mb
    -640 gb WD aacs
    -300w FSP
    -Sugo 05
    Photos hardware:
    Photos case:
  2. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Nice little project there but not sure if that PSU is man enough for that GTX470!! :worried:
  3. Kviker
    Kviker Member
    22 Jan 2010
    coolamasta, it is works :D
  4. Kviker
    Kviker Member
    22 Jan 2010
    Sleeve:
  5. Dragonphreak
    Dragonphreak Member
    26 Oct 2005
    Can't wait to see this one built. I love that SFF is getting more exposure.
  6. Kviker
    Kviker Member
    22 Jan 2010
    24-pin cable is too long, i shortened id.
    And sleeving:
    4-pin shortened
    And with hdd:
  7. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    This is going to be a nice little powerful rig - think I'll subscribe to see what you're gonna do with it.
  8. Matticus
    Matticus ...
    23 Feb 2008
    This is very relevant to my interests, as you can see in my sig :D
    I have my original silverstone fan turned down a little to quiet it down, but I am thinking that I could make use of my pile of silent eagles.
    Judging by your white sleeving, a silent eagle would look epic in there.
  9. djzic
    djzic Bokehlicious!
    8 Nov 2010
    mdpc sleeving? I have some in white too.
  10. Matticus
    Matticus ...
    23 Feb 2008
    Hey Kviker, just a little info regarding the fans.
    Since I last posted, I swapped out my standard fan running at say 60-70% to a silent eagle running at full speed, it is about the same volume but my cpu and mcp have dropped by 2c each.
    Edit: Just noticed you have the golfball style fan, not the one I have which is more "standard" so the golfball silverstone is probably exactly the same the silent eagle.
  11. Kviker
    Kviker Member
    22 Jan 2010
    djzic, yes.
    Matticus, there is no such fans in local shops.
  12. Kviker
    Kviker Member
    22 Jan 2010
    additional side panels... deciding on color scheme
  13. jrs77
    jrs77 Well-Known Member
    17 Feb 2006
    Good to see my work of modelling the Sugo05 being useful :rock:
    Will watch what you do with this case, as I'm currently modifying mine aswell, once the new parts arrive.
  14. Kviker
    Kviker Member
    22 Jan 2010
    jrs77, thanx for model :)
  15. jhanlon303
    7 Sep 2006
    I have an SG.
    Great case. I like your side panel sketchups
    john
  16. Kviker
    Kviker Member
    22 Jan 2010
    jhanlon303, i saw this case on youtube, great painwork, and grills!
  17. Kviker
    Kviker Member
    22 Jan 2010
    Some news...
    New ddr:
    And cpu cooler:
    the complete photo:
    and on motherboard:
  18. Baekkel
    Baekkel Picky Picture Villian
    17 Jan 2010
    looks very promising..
    and now i will turn around, throw my cape and become:
    "THE PICKY PICTURE VILLIAN!!!"
    Those Shadows are doing things to my eyes that would normally make them bleed.. (and yes, that could be possible)
    You seem to have a standard+ camera, add some more light to your setup.
    Flourescent worklights times 5-6 should do the trick, and just adjust the camera's whitebalance to fit the lighting,
    You gain a much lower ISO = Less imagenoise
    Kill the handheld, go tri-pod/equal = allows you to disable the imageStabilizer on most cams = Severely better sharpness.
    allows the camera for lower focalnumber = better macro shots
    the tripod also allows you to set the camera to hold the sensor open longer = again added sharpness.
    "packs the evil cape away for now"
    Looking forward to see your results on your mod :D
    Happy Modding
  19. thegyufi
    thegyufi New Member
    21 Mar 2011
    Really good job, I love the white sleeve!
    Good continuation!
  20. TheRealShep
    TheRealShep ssSSSsssssssSSSSSSSSSsss
    14 Mar 2011
    Kviker, you are doing a brilliant job so far! I will be subscribing to this aswell because I am building one like yours but a little less powerful.
    Keep up the good work!
    Dan
