Windows I've downgraded from XP X64 to regular XP PRO- X64 still showing?
Discussion in 'Software' started by AFCChris, 10 Sep 2006.
  1. AFCChris
    AFCChris What's a Dremel?
    10 Sep 2006
    Hi
    Hoping you guys can help me out. I downgraded from Win Xp X64 OS down to regular Win XP Pro. When doing this I deleted all old partitions and created new ones. Now after successfully installing XP Pro I now get a dual boot menu come up. I'm not really up on all this stuff so can someone tell me how x64 is still around although I deleted everything? I assume it won't work if I choose that option but I would rather it doesn't come up at all and goes straight into XP PRO.
    By the way, not being unfriendly but please don't question why I downgraded. I know it's not the normal thing to do but at the moment it was the best thing for me.
    Cheers
    Chris
  2. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    Funny that, I had the same when I upgraded to XPP from XPH. I just went and took the line out of the bootloader, and turned it off, and all i good. the software isn't there, if you try and load, it should spit back in your face...
  3. hitman012
    hitman012 Minimodder
    6 May 2005
    Edit C:\boot.ini and remove x64's line - it's hidden and read-only by default, however, so you'll have to change those before you can edit it.
  4. Glider
    Glider /dev/null
    2 Aug 2005
    I third that :D
    Just remove te last or the next-to-last line, and you'll be fine (the one that ends with something along the lines of "Windows XP Professional 64bit"
  5. AFCChris
    10 Sep 2006
    Hi
    Thanks for this. I was hoping that there would be a simple answer to this and you guys have provided that. I'll get on and change the boot.ini
    All the best
    Chris
