Hardware J&W MINIX 780G mini-ITX HTPC mobo
Discussion in 'Article Discussion' started by Tim S, 17 Sep 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. The boy 4rm oz
    10 Apr 2008
    I could see this being a great board for a DIY SFF HTPC.
  3. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    is lucky i've not ordered my jetway yet :D, think i'll be picking one of these up :)
  4. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    Ite lads, awesome review :thumb:
    I think this might have just replaced that Jetway that I was considering...
    Just out of interest - your power consumption figures. Are they for the a whole system, or just the board and CPU?
  5. Tim S
    Tim S OG
    8 Nov 2001
    It's full system power consumption :)
  6. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    if the board is 12cmx12cm does that mean it can be mounted on a 120mm fan mount? :)
  7. The boy 4rm oz
    10 Apr 2008
    You could probably make a bracket lol.
  8. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    17cm square no? Thanks, fixed - Tim
    Looks goood, i'm still shocked they get these things under 100w for a full featured proper cpu and all the gubbings.
  9. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    want one! ITX plus PCI-E, might have found a better home for my 8800GTS then! I smell a shuttle upgrade for me, (Shuttle XPC SN41G2, with sempron slowness)
  10. Paradigm Shifter
    10 May 2006
    That is one gorgeous little board. :D
    I wonder if you would have the time to humour a request... would the Scythe Zipang Harry reviewed yesterday fit with it overhanging the NB/SB heatsink? With a 140mm fan pushing air down onto the whole motherboard, that might be an interesting way of cooling the whole kit 'n' kaboodle. ;) Something like the Shuriken might do the same job - that's a 'low profile' HTPC heatsink...
  11. Nature
    Nature Minimodder
    21 Nov 2005
    What kinda case ya'll use fer that there testin'?
  12. Tim S
    Tim S OG
    8 Nov 2001
    Apologies but it's 17cm sq - there was a typo in the article description... :blush:
  13. mclean007
    mclean007 Officious Bystander
    22 May 2003
    If it was overheating when running in spec (i.e. with a <=65W CPU, without overclock), then in my view it is faulty!
    I love my Gigabyte 780G board. Looks like, overheating aside, the J&W is another worthy player.
  14. ChaosDefinesOrder
    6 Feb 2008
    I suppose you could still make a braket for it to fit on a 120mm fan mount...
    (yes this is purely "for the hell of it" speculation!)
  15. Baz
    Baz I work for Corsair
    13 Jan 2005
    No it's the northbridge/southbridge heatsink that overheats when it's stressed by video or graphics and doesn't have any additional airflow. Under nominal circumstances it doesn't need additional air. Because we tested with a heatpiped heatisnk outside of a case there was no additional airflow passing over the board or downward from a lower profile CPU cooler like you would use on one of these boards.
    EDIT: Jeeez Harry, leave yourself logged in!! >_< This is Bindi btw
  16. toru173
    toru173 What's a Dremel?
    13 Aug 2007
    Nice review, I've been looking forward to reading it. Pitty you didn't give Hybrid Crossfire a try! In the text, you mention that the PCIe slot is x8 compatible electrically - but the J&W datasheet lists it as only x4. Which is correct?
  17. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    Very interested if it will fit my Scythe Ninja Mini and MSI 8600GTS heatpipe\silent.
    Will there be much of a performance hit on my graphics card as it's only x8 ?
  18. ChaosDefinesOrder
    6 Feb 2008
    x8 PCI-E v2.0 is identical bandwidth to x16 PCI-E v1 if that means anything...
  19. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    What a cute little board! I just bit on a Gigabyte GA-MA78GM-S2H, so I'm prolly good for now. But this is something I'd consider for a little mod project. Emphasis on little. ;)
  20. The Infamous Mr D
    The Infamous Mr D Minimodder
    11 Feb 2008
    According to this article on Tom's, dropping from a x16 link to a x8 link shouldn't impact performance considerably.
    Sorry for linking to the enemy, peeps :)
Tags: Add Tags
