Scratch Build – Complete ⭐ Jack Daniel's - #OnTheRocks
Discussion in 'Project Logs' started by MT. Mods, 17 Sep 2020.
  1. MT. Mods
    MT. Mods Case Modder
    6 Apr 2016
    Some large updates.
    Over the weekend, i finished the loop, ran a leak test and ran into several issues.
    Majority was recorded, and because of the leaks that happened, i just trashed the video.
    So looks like i'm skipping the build video and just moving to final images + Videos.
    At this moment in time, it's just touch ups here and there that are required, cables to moved around inside etc.
    Anyway, here's a couple shots from last night and a live video of the build that was done on facebook last night.
    Video:
    Thank you for looking
    More to follow soon
    Craig
    douglas alves, Karrek and Cheapskate like this.
  2. Cheapskate
    13 May 2007
    It looks cool with the air still in the lines.
    -Now seal up that side so the little one wont try to drink it!
  3. Yargen
    Yargen What's a Dremel?
    1 Aug 2020
    I love it, the idea with the open loop is great. I was planning to do an Whiskey Mod as well last year, but I tried to wrap my head around placing the computer into an whiskey casket....
  4. MT. Mods
    6 Apr 2016
    Uploaded some final images.
    Was a nice day today, figured i'd get in some shots.
    Will upload more detailed shots over the weekend.
    Thanks for looking
    Craig
  5. MT. Mods
    6 Apr 2016
    #ontherocks is finally finished!
    What an incredible journey it has been.
    Would like to thank our partners
    EK Water Blocks
    CableMod
    XPG Global
    ASUS Republic of Gamers
    AMD Gaming
    Jack Daniel's Tennessee Whiskey
    Without them, this project would NEVER have been possible.
    System Specs:
    ASUS ROG Strix X570-E Gaming Motherboard
    ASUS ROG Strix RTX2080 OC Edition
    MEMORY: XPG Spectrix D60G DDR4 16GB @3200mhz
    SSD: XPG Spectrix D40G M.2 SSD 512GB
    Cablemod: Custom made to order cables
    CPU: AMD Ryzen 3800X
    EK Waterblocks cooling list
    EK-CPU Block Lignum - Walnut
    EK-Quantum Vector Strix RTX 2080 D-RGB - Nickel + Acetal
    EK-Vector Strix RTX 2080 Backplate - Black
    EK-HTC Lignum 10/12mm Fittings - Walnut
    EK-CoolStream Classic PE 360
    EK-Quantum Inertia D5 PWM D-RGB - Acetal
    EK-AF Classic Angled 90° - Black
    EK-AF Classic Angled 45° - Black
    EK-CryoFuel Clear (Premix 1000mL)
    EK-AF Extender 6mm M-M G1/4 - Black
    EK-AF ALU T-splitter 3F G1/4 - Natural Grey
    EK-CryoFuel Dye Pack
    EK-HD PETG Tube 10/12mm 500mm
    Be quiet! (English)
    Dark Power pro 11 power supply
    Extras
    Cooler Master
    MasterFan SF360R ARGB 360mm
    Premium Riser cable
    No return valves (Under shroud)
    Soft tubing for valves (under shroud)
    Custom 15cm USB Extensions
    Custom Kettle plug Extension
    22 wooden slats
    12 A4 size birchwood sheets
    Jack Daniel's Bar mat
    Jack Daniel's Tumblers
    Jack Daniel's 1L Whiskey Bottles
    The system has 2 reservoirs that are interchangable.
    One = Closed loop, no evaporation or dust.
    Two = Open loop, water falls from bottle to glass. (for show event use)
    Thank you to everyone who viewed, commented and shared the project.
    If you'd like to follow all future updates (shows/events or what happens next) check out https://www.facebook.com/MTMods
    Thank you again.
    <3
  6. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    I came back to this today as something occurred to me earlier that reminded me of this build.
    Very much impressed (as was the non-tech, JD fan missus). The functional mods (this one with the pouring bottle and matching theme, the PUBG one, the toaster one here on Bit and the blood bag/medical one I've seen elsewhere) always have more wow factor to me than simple liquid loop builds with some RGB on top, or a snazzy case but with components just bolted inside as normal.
    I need to lift my game! :thumb:
  7. Ragster
    Ragster What's a Dremel?
    27 Aug 2021
    Amazing build! It looks like the pictures aren’t working where you talk about the coolant. Do you remember what you mixed to get the brown color? Sounds like yellow and… ??
