News JacolTech Braided Wire Sleeving at TwistedMods
Discussion in 'Article Discussion' started by GreatOldOne, 29 Aug 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Ok - you've all seen G-Gnome's ORAC, and you've seen how cool sleeving can look. Want to do it yourself? TwistedMods have just reviewed a whole shed load of braid:
    "Sleeving your power supply, as you can see, will surely make your computer look extremely high quality as well as professional if done correctly. This is by far the cheapest and most effective way to give your computer that extra bit of TLC it needs. JacolTech sells a very high quality product as you can probably tell from the description of the braided sleeving above. If you want one of the best looking rigs at the local LAN party, picking up some braided wire sleeving from JacolTech is the first choice you should make."
    Join the Braidy Bunch here ;)
Tags: Add Tags
