Apple JailbreakMe 3.0 for all latest iOS devices!
Discussion in 'Software' started by wyx087, 6 Jul 2011.
  1. wyx087
    15 Aug 2007
    being a huge jailbreak user, it's my delight to post on Bit-tech that JailbreakMe.com have released the latest and easiest jailbreak in iOS history.
    works with these devices:
    • iPad1: 4.3 through 4.3.3
    • iPad2: 4.3.3
    • iPhone3GS: 4.3 through 4.3.3
    • iPhone4: 4.3 through 4.3.3
    • iPhone4-CDMA: 4.2.6 through 4.2.8
    • iPod touch 3g: 4.3, 4.3.2, 4.3.3
    • iPod touch 4g: 4.3 through 4.3.3
    tested on my iPad 2 4.3.3 this morning, faultless and effortless, much easier than installing an app from appstore. feel exactly installing an app from appstore, except none of the password-entering rubbish.
    once Cydia is on your device, you are good to go. i recommend the following cydia addons to get you started:
    • SBsettings (pull-down toggle for quick access to your settings)
    • Activator (comes with SBsettings)
    • MobileNotifier (iOS 5 or Android style notification)
    • MultiCleaner (huge customisation for app specific multi-tasking stuff)
    • PDF Patcher 2 (to stop the PDF exploit used in this jailbreak)
    • SpringFlash (adds activator toggle for your LED flash, aka fast flashlight)
    • WiFi Analyzer (useful for finding free wifi around you)
    also, due to the PDF exploit used in this jailbreak, if you install PDF Patcher 2, your device will not be open to further attack from same exploit. making your device a LOT more safer than stock apple devices. one more reason to jailbreak :thumb:
    http://www.jailbreakme.com/
    do it, there's ZERO reason not to!
  2. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    Does jailbreaking it this way still work after a power off?
  3. wyx087
    15 Aug 2007
    yes, it's untethered.
    and you no longer require a device restart after jailbreak, Cydia installs just like any other Appstore install. Easiest jailbreak ever!
