Case Mod - In Progress Jam Packed - InWin A1 Mod
Discussion in 'Project Logs' started by Mosquito, 5 Feb 2020.
  1. Cheapskate
    13 May 2007
    *Pushing on the PCIE mount.
    Mosquito: "Yeah, It totally fits." :lol:
    cobalt6700 likes this.
  2. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    lol Because of the bevel on the edge of the Hardware labs radiators, it's not actually touching anything, it's just REALLY close lol It's just the little clip that snaps over the back part of the card/riser to hold it in place that will hit
  3. Mosquito
    24 Mar 2011
    Howdy!
    Part 4 of the video series is up, and tacking how to mount dual GPUs in this thing
    So, the starting point was one of Bill's (MNPCTech) Stage 1 vertical GPU bracket
    Thought about trying to mod my hardware to make them both single slot cards, but instead decided to prototype a dual GPU mount in the same idea. Mounts in a 120mm fan spot, holds 2 GPUs. First prototype out of MDF
    Instead of a slitting saw to make a slot for the bottom of the PCI covers, I just cut a recess and use screws + washers to hold the GPUs against it
    Then back to the CNC to make one out of acrylic, using threaded inserts since I didn't have a tap the right size at the time (later fixed that problem)
    Again, this one worked well, so I made one out of aluminum intended as the final
    Drilled and tapped all the holes for this one
    And this worked great!
    However, it only worked great for the GTX 760s... My Vega 56 Nano's that I've decided to switch to, are a little taller, and as such they are too tall with this bracket... Dang it!
    So.... slight redesign, to drop the GPUs down a little bit (it was already mounted as low in the 120mm slots as I could get it)
    And this was just enough to drop it down below the top
    Then I cut out the raised mesh from the fan hole in the cases (Video Only, subscribe to my OnlyFans to see that... /kidding)
    But anyway, then I made a cover plate to go over the ugly, since I had to cut out more mesh than I needed to for the GPU mount, so I could keep it flat
    And installed that in the case to get an idea of what it'll look like
    And.... that will pretty much do it for this time around :)
  4. Cheapskate
    13 May 2007
    It looks like you figured out your cut issues on the 2nd one.
  5. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Really nice!
  6. Mosquito
    24 Mar 2011
    lol yes, went in to that a little in the video, it was set up way too aggressive in the first aluminum one. Also took apart the z-axis carriage and tightened things up a little, as some of the V-wheels had worked a little loose. Also adjusted the tool paths a little too, with actual finishing paths and what not
    Thanks!
    Osgeld likes this.
  7. Mosquito
    24 Mar 2011
    So it's time to take a look at the reservoir/pump in this thing, and make a first pass at getting that figured out. Also a quick mock with some other stuff to see just how things are fitting in there
    Not too many pictures for this one, basically just drilled and tapped a hole in my Watercool pump top reservoir so I could have a different port location on it for having return to the pump there, or a fill/drain port later. Will also be thinking about a custom res+pump combo for this thing too...
    Thanks for checking it out, hopefully back soon with another installment
  8. ivory2k19
    ivory2k19 Minimodder
    8 Feb 2019
    Looks great :thumb:
    Is this your own cnc?:dremel:
  9. ciaognep
    ciaognep Minimodder
    10 May 2020
    very small case work well done :rock::rock::rock::rock:
  10. Mosquito
    24 Mar 2011
    Thanks! Yeah, this is a CNC I got about 7 months ago. Still learning a lot :eeek:
    Thanks, the small cases are often my favorites, I enjoy the challenge :dremel:
  11. ivory2k19
    8 Feb 2019
    nice machine, maybe one day :hehe:
  12. ciaognep
    ciaognep Minimodder
    10 May 2020
    I see...
  13. kim
    kim hardware addict
    10 Jan 2016
    lovely build....the GPU bracket is insane :rock:
  14. Mosquito
    24 Mar 2011
    That's what I kept telling myself, for like 5 years lol Finally managed to save up enough to buy the CNC last year. Too many other things kept taking priority before it :)
    Thanks, it's the key to the whole mod, otherwise it would have just been a single vertical GPU lol
  15. Cheapskate
    13 May 2007
    2" plexi? DO IT!
  16. Mosquito
    24 Mar 2011
    I plead the 5th lol :grin:
  17. Mosquito
    24 Mar 2011
    Another update, this time trying to figure out which top window I should go with
    For the first top panel, I painted it white on the top and the bottom. This was the one that had the magnets on the bottom, so I didn't want to see that through the clear acrylic
    I put a small bevel around both of these with a router to match up better to the I/O panel
    The second top panel was painted with a metallic silver on just the back side of the panel. This one didn't have magnets so I could get away with that
    Same bevel on this one, and I really like the way this one looks, but I'm not quite sure it fits with the case that great
    Sooo yeah. I'm not sure, I think I'm leaning towards the white top panel, but haven't completely decided yet. Could always paint other parts to make it go a little better, I suppose.
    kim and ivory2k19 like this.
  18. idpcmods
    idpcmods Minimodder
    30 Jun 2015
    The whites a better fit, the silver seems like it conflicts the brushed aluminium... If you had a darker shade the brushed effect can be achieved with paint which I feel would look killer
    Mosquito likes this.
  19. Cheapskate
    13 May 2007
    Let the paint set up really well, then mill some speed grooves with your smallest bit. Then paint it again with a slightly darker silver.
  20. Mosquito
    24 Mar 2011
    Thanks! Not a bad idea
    Hmm... paint/clear has been cured for a while now, so that should be ok... I might have to give this some though, as I was also trying to come up with something to do with the back cover plate for the dual GPU mount as well
