News Japanese T-ray tech boasts 3Gb/s wireless speeds
Discussion in 'Article Discussion' started by brumgrunt, 17 May 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    I predict a Resonance Cascade with those high frequencies!
  3. Gareth Halfacree
    4 Dec 2007
    "I never thought I'd see a resonance cascade failure, let alone cause one!"
  4. Bazz
    Bazz Multimodder
    7 Oct 2009
    Gordon's ALIVE!
  5. Bede
    Bede Minimodder
    30 Sep 2007
    Now we just need storage with the ability to read/write at similar speeds.
  6. B1GBUD
    29 May 2008
    Close, but not close enough methinks.
  7. Gareth Halfacree
    4 Dec 2007
    That's not a problem: pretty much any mid- to top-end consumer SSD can handle 500MB/s read and write, which is 4Gb/s.
  8. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    One major problem I foresee: bad science.
    If wireless is bad for us (my acupuncturist homoeopath told me it was, so it must be true) and that works in the GHz range - so surely something that works in the THz range must be a thousand times worse for us? ;)
    How long before the luddites suggest something like that?
    On a more serious note, any wireless system that is capable of working through my 2 foot thick walls would be very welcome by me. It's a shame that we're probably at least 5 years away before a viable commercial version is available...:(
  9. blackerthanblack
    blackerthanblack Minimodder
    17 Sep 2004
    The problem with getting workable solutions at this frequency is that it gets much harder to have a reasonable output power, which means short range. One of the other main problems is tuning which involves tailor made parts and lots of testing/retuning to get right (although that's going on my experience of top end R&D equipment so it may be that they've cracked it for lower/consumer parts).
  10. Gradius
    Gradius IT Consultant
    3 Feb 2009
    At 1THz and up, your DNA starts to cracking down. No, I'm not kidding at all!
  11. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    that's really high freq.. I'd like to see the antennae that delivers- sounds like a gimmick if it has no range
  12. thehippoz
    19 Dec 2008
    oh well threw some numbers into a modeler.. you could theoretically get 4x the distance using a small 3 element yagi =] but the f/b ratio is horrible not to mention the pattern, needs a lot of tweaking.. least the numbers put it in the ballpark though
    why not just run a cable :D
  13. mauvecloud
    mauvecloud What's a Dremel?
    4 Nov 2008
Tags: Add Tags
