Development java game help!
Discussion in 'Software' started by brighty22, 30 Sep 2010.
  1. brighty22
    brighty22 What's a Dremel?
    19 Aug 2010
    I started my computer science ib 3 weeks ago, and have been asked to create a simple game where a random number is chosen by the program, and the user has 5 chances to guess the number.
    I've got a problem with the 'sorry, you lost' bit... I need to show a percentage error of how far out the user was. g3 is the number the player guessed on their final chance.
    Code:
    else {
        int pce;
        if (g3>number) {
            pce = (((g3-number)/g3)*100);
        if (g3<number) {
            pce = (((number-g3)/number)*100);
        System.out.println("No: the number was "+number+". Unlucky, you were only "+pce+"% out!");
    BlueJ highlights the second last line, saying variable pce hasn't been initialised... any ideas why? :wallbash:
    I can post the rest of the code (108 lines) if it would help :)
    Thanks :thumb:
  2. capnPedro
    11 Apr 2007
    Try changing int pce; to
    Code:
    int pce = 0;
    thehippoz likes this.
  3. brighty22
    19 Aug 2010
    genius :thumb: but why do you have to give it a value for it to be initialised? (just so I understand for next time :))
  4. capnPedro
    11 Apr 2007
    It's been a long time since I did any Java, but if I remember correctly, you have to initialise all local primitive data types like that because the compiler doesn't assign them an initial value.
  5. JazzXP
    JazzXP Eh! Steve
    30 Apr 2002
    This. Local variables have to be initialised, class variables get default values (typically 0 or null depending if it's a primitive or an object)
  6. brighty22
    19 Aug 2010
    right, thanks to you both :)
