Development Java & InputStreams
Discussion in 'Software' started by simon w, 12 Apr 2004.
  1. simon w
    simon w What's a Dremel?
    3 Nov 2003
    I'm trying to write a piece of code that connects to a web server, grabs a file (of any type) and saves it locally. So far I have,
    Code:
    URL u = new URL(args[0]);
    URLConnection connection = u.openConnection();
    HttpURLConnection httpConnection = (HttpURLConnection)connection;
    InputStream in = connection.getInputStream();
    FileOutputStream outputStream = new FileOutputStream("file.txt");
    while(in != null)
    	outputStream.write(in.read());
    outputStream.close();
    At the moment this grabs the file passed to it from the command line (e.g. www.google.co.uk). The problem is the end of the stream never seems to be reached, instead a never ending number of ÿ's are added to the end of the file,
    I've tried changing the
    Code:
    while(in != null)
    bit to
    Code:
    while(in != -1)
    but that doesn't make any difference.
    Anyone know what I'm doing wrong?
  2. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    at a guess its getting from the buffer -1 (0xFFFFFFFF in 32bit), but its been cast to char, not used much java lately i'm affraid, so i can't remeber if it will cast properly in an indentically equal too comprasison.
    Easyest way would be to say while !=0xFF
    but that would have problems when that chr occoured in the data.
    but anyway isn't that a in.EOF or in.notEOF?
  3. simon w
    3 Nov 2003
    I coundn't find anything to do with EOF...
    Anyway, this seems to have fixed it (edit: and it works nicely for other file types :) )
    Code:
    int next = in.read();
    while(next != -1)
    	outputStream.write((byte)next);
    	next = in.read();
