Development Java: Visitor IP Address
Discussion in 'Software' started by Xiachunyi, 23 Jul 2004.
  1. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    Hello, I know this question probably has popped up over and over but searching the forum yielded nothing and I am too overwhelmed with information via the internet search engine.
    My question is: How would you obtain a visitor's IP address that is visiting your webpage in Java if possible?
    Thank you.
  2. Ben
    Ben What's a Dremel?
    11 Aug 2003
    first thing i came to::
    but then got this link
    on my hosts servers i can add the code <!--#echo var="REMOTE_ADDR" --> to the page to show the visitor's IP I need to put it in a .shtml file though. same as ^^
    i also found this link its php though
  3. simon w
    simon w What's a Dremel?
    3 Nov 2003
  4. Xiachunyi
    3 Nov 2003
    Thank you both for the reply. :D
    Java and Javascript :duh:
