Development Javascript mouseover menu
Discussion in 'Software' started by Millusdk, 15 Jun 2008.
  1. Millusdk
    Millusdk What's a Dremel?
    27 Jan 2008
    Hi
    I am looking for a guide on how to create a javascript menu. What i want is a horizontal menubar, on wich 2 of the menu items need to have vertical menus that apear below them. Does anyone know any guides that can help me crate this?
  2. klutch4891
    klutch4891 What's a Dremel?
    4 Feb 2008
    I dont know about a guide for it but I have something like that made already if you would like a copy of it.
  3. Millusdk
    27 Jan 2008
    That would be nice
  4. klutch4891
    4 Feb 2008
    well I found the html portion of the code but I cant find the javascript section just yet. :wallbash: Ill keep looking though.
    I just put those into the head and body respectively and used CSS to dress it up and position each one. theres most likely an easier solution to the problem but it works for me.
  5. OleJ
    OleJ Me!
    1 Jul 2007
  6. RickDawson
    RickDawson Minimodder
    29 Mar 2006
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Also look at the CSS menus here, some people have JS switched off.
    The style you describe looks to be this one.
    Nicest I've come across is Transmenus. It's commercial if you want templates, but there's a free earlier/basic version from the original code author Adam Boordman somewhere.
  8. Millusdk
    27 Jan 2008
    It is exactly that style of menu I am looking for :rock: Thanks a lot
  9. Millusdk
    27 Jan 2008
    Well i have adopted parts of their menu for my website, however i does not work in IE7 :confused: on their site it works no matter what browser i use IE7 / FF3b5
    I have also tried to copy the menu as they say you should onto a blank page, and it doesn't work here either :wallbash:
    you can see the blank page one here http://test.icgentofte.dk/test.php
    I am starting to think it might be a problem with the setup on the server.
