Case Mod - In Progress Jeff's HTPC A.K.A the happy hippy
Discussion in 'Project Logs' started by Tec_, 21 Jun 2008.
  1. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    evercoat everglass?
    tell me more please... this is the first I've heard of it. I wanted to play with bondo on a future mod, what makes this stuff better? easier to use, better looking, less toxic?
    BTW- if you make it up to Oakland on your trip to Cali, you're welcome to drop me a line.
    Oh yeah, and it's looking good! I like that fan and blowhole combo, can't wait to see it finished up.
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    You found the Evercoat! :thumb: Just a warning, it gets real dusty when you sand it. You should also invest in a filtered respirator or mask if you haven't already.
    @ ModMinded, it's a fiberglass filler, it spreads easier, cures faster, and it's stronger than Bondo. It also has Kevlar strands in it, so it will flex if stressed, which is ideal for plastic bezels.
    Bondo also shrinks as it cures, which can cause hair line cracks. The thicker the Bondo application, the worse the problem.
  3. ModMinded
    26 Aug 2008
    Right on Bill, thanks for the answer/tips.
    /hijack
  4. Tec_
    Tec_ New Member
    26 Feb 2008
    evrything bill said was right on. It was so much better to work with.
    And I will be in the oakland area the rest of the week (wallnut creek) I'm driving up from salinas later today
    Looks like it might be a week or two before I make it back home
