Hardware Jetway NC92-330-LF dual-core Atom mini-ITX
Discussion in 'Article Discussion' started by Tim S, 24 Mar 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    The Jetway/Sempron combo looks a lot more interesting then the Jetway/Dualcore Atom. As of this fact alone its a bad review for the JW/DC atom board. you should have left the JW/Sempron out of the benches. Then it would probably be a better review ;)
  3. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    err, so what is the best solution for a low power server? low energy sempron, low energy core 2 (whatever)? or atom?
  4. Guest-16
    Guest-16 Guest
    What are your performance needs? For next to no CPU demand the Atom, for more intensive applications the Sempron.
  5. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    Sempron and AMD X2 45W......
    Just picked up an itx Jetway NC81-LF and a 2.6GHz 45W x2 for a low power fileserver with a RAID card. 4x1Tb in RAID 5 will be fun, and dual GigE PCIe connectors onboard....
Tags: Add Tags
