Modding Jigsaw Vs Dremmel ?
Discussion in 'Modding' started by j03, 3 May 2002.
  1. j03
    j03 What's a Dremel?
    14 Mar 2002
    Im planing to cut a 120mm fan hole out the side of my case and im thinking whats best to cut it with ? Jigsaw or dremmel.
  2. ChenZen
    ChenZen Minimodder
    5 Mar 2002
    neither, use a drill, holesaw, and arbour.
  3. yfan
    yfan What's a Dremel?
    2 May 2002
    i know this isn't really the best way but i drilled a hole, used a nibbler and sanded the circle smooth, doesn't matter much my fan grill covered it up
  4. Vectrex
    Vectrex What's a Dremel?
    21 Apr 2002
    Still... if you want the cleanest, best looking results, definetely use a holesaw. You will be so pleased with your results, I guarantee it. :)
  5. kanuslupus
    kanuslupus Minimodder
    10 Mar 2002
    Assuming you are asking because you don't have/can't get/afford a holesaw, then I would think a combination of the two.
    Jigsaw for the bulk of the work, then maybe the dremel for more detail work, than filing to finish. Just a guess. I picked up
    a 92mm holesaw for US$39. More than I'd wanted to spend, but oh well. Now for the time to use them.
  6. Lazy
    Lazy Meow?
    13 Nov 2001
    use the jigsaw to cut the hole out as i found that when i tried cuting a blowhole with a dremel the dremel could only do straight cuts so it was cutting otuside of the circle template.
    Instead i used a jigsaw and then finished it off with the dremel de-burring attachments. Then you can get some blowhole rubber and it covers up your mistakes and makes it look better.
    I have to agree though that using a holesaw if i could have afforded it would have been a lot quicker, easier and would have looked a lot better.
  7. god8y
    god8y What's a Dremel?
    15 Mar 2002
    look i've bought a holesaw too, now i am addicted too it, it's fast and easy and its looks sweeeeeeeeet (u can't get it rounder)
  8. j03
    14 Mar 2002
    Yeah I think ill have to get a hole saw just cost £15 and i could buy the fan for the hole with that. :) thx guys
  9. chrisw007
    chrisw007 What's a Dremel?
    28 Jan 2002
    I wouldnt go for the hole saw as its quite expensive. Use a jagsaw, its the cheapest and most effective way.
    Everyone as an oppinion, its just your preference :p
  10. kanuslupus
    10 Mar 2002
    Cheaper is relative. I already own a drill, so the holesaw is much cheaper than the Jigsaw alternative.
  11. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    a 12cm hole saw is quite expensive man. thats why not alotta people use it.
    everything suggested will work, its a matter of what you want to do and what youre comfortable with. practice first. i had a choice between a dremel and a jigsaw, and i chose dremel because the chances of me dremeling myself or my case apart was much smaller then with a dremel.
