Case Mod - In Progress ⭐ Jonsbo VR1 - Kupfer & Bling Bling
Discussion in 'Project Logs' started by flix, 4 Jan 2020.
  1. flix
    flix Minimodder
    5 Aug 2009
    Hey,
    I would like to introduce you to one of my projects in this worklog.
    I admit, this time it won't be the glamorous worklog. The photos were all taken in passing ...
    But I think you can still understand the process quite well.
    My last project was a Caselabs SMA8. Maybe one of you has followed project "Monochrome" ?
    Anyway, after this huge case I wanted something small again.
    Some ideas:
    - external radiator
    - full control and a big bunch of sensors for the watercooling loop
    - copper tubes
    - try to hide all cables as good as possible
    - using a SFX instead of an ATX powersupply to get some roome for watercooling
    hardware:
    - Intel Core i7 6700K
    - Asus Z270 ITX
    - 16 GB Crucial Ram
    - Zotac GTX 1080ti
    - Corsair SF600
    watercooling:
    - Watercool - HEATKILLER® IV PRO - PURE COPPER
    - Watercool - HEATKILLER® IV for TITAN X and GTX 1080Ti - ACRYL
    - Watercool - MO-RA3 420 LT black
    - Noiseblocker - eLoop Fan B14-PS - 140mm PWM
    - Aqua Computer - Aquatube Kupfer
    - Aqua Computer - Aquaero 6
    - Aqua Computer - Durchflusssensor high flow G1/4
    - 2x Alphacool - Eiszapfen Temperatursensor
    - Bitspower - various adapters
    - Barrow - various adapters
    The Case:
    For those of you, who didn't know the case I'm working on:
    A big shout out to Blacknoise und Watercool.
    Both are two great German innovative companies that supported me on this project.
    Thanks. [​IMG]
  2. flix
    flix Minimodder
    5 Aug 2009
    Update No. 1: bracket for pump and terms and reservoir
    I started by taking the measurements off the Aquatube.
    I sawed off a piece from a large aluminum angle:
    I then simply transferred the dimensions for the reservoir and roughly cut out / drilled the corresponding shapes.
    I held it similarly with the pump holder, first transferred the fixed dimensions and then added the "free forms".
    After some reworking with a drill, saw, file, sandpaper, the two brackets looked ready and are ready to paint.
  3. Mizuwari
    Mizuwari In vino veritas
    19 Sep 2018
    Really nice handwork on the aluminium parts!
    flix likes this.
  4. arduum
    arduum Minimodder
    10 Mar 2015
  5. kim
    kim hardware addict
    10 Jan 2016
    :clap:great start with those aluminium brackets, what will you use for painting it ?, I heard that aluminium hates paint...:idea:
  6. flix
    flix Minimodder
    5 Aug 2009
    Thanks. :cooldude:
    It's normal paint for cars. Some primer first and normal paint after that.
    Update:
    As I have already written, the space for the ATX power supply should be used for an SFX power supply + Watercooling components.
    So I need to create a panel to hide this stuff.
    Expert sketch :D
    I transferred the dimensions to an aluminum sheet and cut it out.
    In order to be able to bend the sheet more easily, I "scratched" the marked bending edges with the Dremel.
    So its much easier to bend the aluminium and you have a nice angle
    To mount this panel I've cutted some profiles and used rivet nuts to use M3 screws for assambling.
    That it for now. :clap:
    Dot_Kappa, Cheapskate and craigbru like this.
  7. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    Great start so far! I'm looking forward to seeing how you cram all the watercooling in there. I'm liking smaller cases more and more these days.
  8. Cheapskate
    13 May 2007
    You had my attention at "big aluminum angle." :lol: Lovely work.
  9. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I know the feeling of working with "heavy metal" lately
  10. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Nice trick :naughty:
    flix likes this.
  11. flix
    flix Minimodder
    5 Aug 2009
    It's possible to fit a watercooling setup in nearly every case. But its no fun ^^ After this case i will definitly switch to a normal atx case again.
    hehe, thak you sir. :)
    It sucks ^^ Sometimes it will not end... but in the end the result is totally worth it.
    Small Update:
    another "heavy metal" angle...
    this angle is needed to mount the aluminium cover panels.
    yeah.. maybe it would be much easier to take a normal angle and use some rivet nuts :D
    First test fit:
    new aluminium sheet for the side panel
    first copper tubes bent:
    Thats it for now. :)
  12. Cheapskate
    13 May 2007
    You are using space like you have plenty to spare. :D
    flix likes this.
  13. kim
    kim hardware addict
    10 Jan 2016
    :clap:splendid !! I love it
    flix likes this.
  14. flix
    flix Minimodder
    5 Aug 2009
    The whole setup will be cooled by one Watercool MO-RA 420.
    The Mora will be equiped with 9x NB-eLoop Fan B14-PS Black Edition - 140mm PWM. IN my opinion an amazing combination
    eLoops [​IMG]
    The GTX 1080ti will be cooled by a HEATKILLER® IV for TITAN X and GTX 1080Ti - ACRYL
    Next time, there will be another working process update. :)
  15. Cheapskate
    13 May 2007
    Make it fit inside. You can do it. :thumb:
    flix likes this.
  16. Vault-Tec
    30 Aug 2015
    Lovely :D
    flix likes this.
  17. Mizuwari
    19 Sep 2018
    It's been a loooooooong time since I last saw a project with the Noiseblocker ELoops. They are still soooo sexy (and non-RGB Cheesecake) :clap::thumb:
    flix and Dot_Kappa like this.
  18. flix
    flix Minimodder
    5 Aug 2009
    Thank you guys.
    I also think that those noiseblockers are one of the best looking fans on the market.
    I'ves searched a long time for a Aquatube copper edition. finally I've found one :)
    the untreated reservoir:
    Cleaned the tube and mounted it to the painted brackets.
    First time all parts together [​IMG]
    Here you can see also the aquaero 6 and the pump
  19. flix
    flix Minimodder
    5 Aug 2009
    Some small updates on electrics. :)
    I want to hide the cables as much as possible, for that I've build a 90° adapter for the 24 Pin ATX cable.
    This flat ribbon cable disappears directly under the psu cover.
    A little bit more special is the powercable of the GTX 1080ti. I gave this approach a try some years ago on a GTX 970 and it worked fine.
    So I repeat it for the actual project.
    I don't have any pictures of the building process so I try to describe it:
    1. Cutting a plate out of a circuit board. I think the copper is 210µ on both sides
    2. put a notch via dremel on the circuit board for dividing the both potentials
    3. used some thick wires and crimped some pins on it
    4. all pins put into the circuit board and soldered them
    5. Big power cable with big profile soldered on both potentials
    The power cable isn't visible anymore because its hidden under the waterblock. :)
  20. kim
    kim hardware addict
    10 Jan 2016
    This is just :jawdrop:... top modding :dremel:, I am impressed :clap:...I mean, the whole project is awesome but what you've done with the GPU power is amazing :wallbash:
