Development jQuery: simplify this?
Discussion in 'Tech Support' started by jezmck, 25 Jan 2009.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    Code:
    $(".menu a[@href$=cat/5]").parent().addClass("active").parents("ul").show().addClass("open");
    $(".menu a[@href$=cat/5]").parents("li").addClass("open");
    Can this be simplified to a single line? (or in anyway?)
    Relevant HTML:
    Code:
    <ul class="menu hier open">
     <li id="menu2" class="parent open">Peripherals
      <ul>
       <li id="menu3"><a href="/cat/3">Input</a></li>
       <li id="menu4" class="parent">Output
        <ul>
         <li id="menu5"><a href="/cat/5">CRT/LCD Monitor</a></li>
         <li id="menu6"><a href="/cat/6">VFD/LCD Panel</a></li>
        </ul>
       </li>
      </ul>
     </li>
    </ul>
    Any suggestions welcome :)
    see http://beta.scc.jezmckean.com/cat/5
  2. Firehed
    15 Feb 2004
    I assume you're generating the jQuery dynamically based off the current URL, right? Wouldn't it be easier to just add the classes dynamically to the list instead, or is that not a feasable option?
    You can try
    Code:
    $(".menu a[@href$=cat/5]").parent().addClass("active").parents("ul, li").show().addClass("open");
    but no guarantees. If that dual selector doesn't work, I don't think it's otherwise possible without needlessly complex DOM traversal.
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    Yep, it should be but the function is recursive and complex enough already.
    Will give it a go.
    Okay, many thanks. :D
