Development jSlideshow - javascript slideshow creator
Discussion in 'Software' started by alter_ego, 31 Oct 2006.
  1. alter_ego
    alter_ego What's a Dremel?
    26 Jun 2004
    Basically jSlideshow is a javascript slideshow creator, you just wrap your images, in a div tag with an id of jslideshow, and the javascript will do the rest producing a nice little slideshow.
    To fully understand you would be better off checking out the demo at http://therootdesign.co.uk/jslideshow
    Any feedback is appreciated.
  2. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    Looks cool, I'll spend some time messing around with it as soon as I find a need for it. I presume it is easy enough to change the colours?
  3. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    That IS really cool... I'll definitely use this!
    Is there a way to add a feature to turn off the numbering at the bottom?
    Also adding a A href to an image for going to a place that relates to the image?
    Is the box only as big as the largest image? Or do you set that up with the CSS and the DIV?
  4. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    that looks great.
  5. jezmck
    jezmck Minimodder
    25 Sep 2003
    jquery is brilliant - i keep finding more and more plugins.
  6. alter_ego
    26 Jun 2004
    Sorry, i havent replied, yeh i'll try an add a feature for a custom link.
    As far as customising it goes, I'm re-writing the code so that it references to a css file for color customisation etc.
    I've also added in a loading animation.
    I'll upload it a bit later on today.
  7. Lazlow
    8 Aug 2003
    Sounds good, keep us updated with where it's at!
  8. alter_ego
    26 Jun 2004
    cool, thanks for the intrest.
    I've completely re-written the code, and produced a slightly more professional looking slideshow, over here, http://therootdesign.co.uk/applications/ourapps . If you lot like it, I'll annotate the code, and upload it for everyone.
  9. Lazlow
    8 Aug 2003
    The second version is great! I like the way that it looks flash based, but isn't - only thing I don't like is that clicking on 'images' throws me to the top of the page again - on a large page it would confuse the users. Upload it and don't forget to credit yourself in the source - after all it's your work.
  10. alter_ego
    26 Jun 2004
    thanks, didn't notice that error, so I just updated it. Basically the code right now is a bit messy, as in it unannotated and unclear as to whats going on. I'll get that updated in the next 1-2 days and then upload it, and i'll make sure to label it as my work!
  11. Lazlow
    8 Aug 2003
    Perfect - now I can't see anything wrong with it.
