Case Mod - In Progress JUMBO CASE - FİNAL-
Discussion in 'Project Logs' started by arg-ist, 13 Jan 2014.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    part 1
    At one of my friend’s request we have planned a case so;
    The case will be made for 2 MB.
    It will have the opportunity of a large watercooling
    The Evo radiator which is used will be moded. From 3 channels, the one in the middle will be connected to the compressor.
    With this radiator, if it is needed, by running the compressor, extra cooling can be provided.
    The frame of the case is sheet iron profile(saç kutu profil).
    I used 2 mm aluminum plates.
    Then , firstly it is undercoated with epoxy ground coat, later it is painted mat black with spray paint .
    The necessary plexi pieces have been done by me .and it is delivered to my friend as a naked case.
    After this, hardware will be established by him.
    I completed my duty by making the case only.
    The next phase is depend on my friend’s studies.
    part 1
    http://www.youtube.com/watch?v=tHymphNgp4g
    part 2
    http://www.youtube.com/watch?v=tzW-a5JZ7W8
    OTHER WORKLOGS
    PlayDoh Silverstone TJ07 - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=267324
    SAK SAK 900 D CASE
    http://forums.bit-tech.net/showthread.php?t=271227
    TERMINATOR CASE
    http://forums.bit-tech.net/showthread.php?t=267028
    12 Angry Men 900 D Case
    http://forums.bit-tech.net/showthread.php?t=266585
    mmt 900D Case
    http://forums.bit-tech.net/showthread.php?t=266954
    ER36PO Level 10 GT - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=269227
    How to make BENCH CASE from an old ATX
    http://forums.bit-tech.net/showthread.php?t=277334
    self made COSMOS II Clear Panel
    http://forums.bit-tech.net/showthread.php?t=277478
    Graphic Equaliser Display
    http://forums.bit-tech.net/showthread.php?t=277610
  2. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Wow that is a huge case indeed.
  3. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    That - is gigantic! I don't fully understand what you mean about some of it so excited to see how it unfolds!
    When you say "compressor cooled" - I am guessing some kind of single stage/phase change is happening there? I am real unclear in my head how you and doing that with the rad so yeah, I look forward to seeing more :) Are you going to use the center channel as your evap in a phase change system and then the left and right channels will benefit from how cold it is? That's about the only way I can make sense of it!
  4. Parge
    16 Jul 2010
    ZOMG!
    Just as I'm going ITX some people are going DOUBLE ATX!
    Can't wait to see this fully loaded with rads.
  5. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    **** ITX !
  6. itrush07
    itrush07 Minimodder
    28 Nov 2007
    Can't wait to see the final output.. please share it here so we can see how it looks and how awesome it is. Thanks.
  7. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Hi
    First excuse me form my english.
    Im interested with the build of the case ,as I said…Cooling is not my log.but ı can say.
    He modded Evo 1080 ,and used center chanel of 3 chanels Evo 1080, for comressor , and then the left and right channels for watercooling.like a plate Heat Exchanger (Koolance )
  8. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    This is insane. And i love it!
  9. arg-ist
    arg-ist Minimodder
    21 Dec 2013
  10. longyny
    longyny What's a Dremel?
    8 Aug 2012
    Overkill!!
    Let's see how it looks once finished. I'd put Aquadrives instead of those homemade hdd waterbloks, Aquacomputer is superb quality and they look very nice
  11. The_Crapman
    5 Dec 2011
    ohmygodsomuchcopper:jawdrop: :jawdrop: :jawdrop: :jawdrop:
  12. iggy
    iggy Minimodder
    24 Jun 2002
    seriously, wtf? he just built the exact same thing for probably peanuts, that do the exact same job, with the kind of satisfaction that only comes from not buying off the shelf components. ****, why bother making any of it? you can buy cases from ebuyer.
    this is going to be an awesome crazy bit of kit, loving it dude, keep going. i wish i had access to the kind of tools youre using :)
  13. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    I am glad , that you have bought an Aquacomputer hdd WB, becouse i am a reseller of watercool products in my country, and have them on my shelf to sell .
    But i like to make my parts self.
  14. Cheapskate
    13 May 2007
    :thumb:
    My first thought was: "We're gonna need a bigger bed.":lol:
    Looks awesome, and HUGE!
  15. Egami
    Egami Why is the dremel on fire?
    27 Aug 2013
    Hope you have a big house as you're going to need a forklift to move that thing once it's ready. Count me in!
  16. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    People still use mechanical drives?? Weird
  17. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Of course it is a big case…JUMBO , but how much . We can compare
    Corsair 900D is:
    25.6’’ X 27.2’’ X9.9’’ (650 mm X 692 mm X252 mm)
    Magnum STH 10 is:
    32.25’’ X 26.56’’ X 11.25’’ (819 mm X 675 mm X 286 mm)
    And JUMBO is
    35.30’’ X 29” +11’’ X 11’’ ( 900 mm X 800mm + 300mm X 280 mm)
    I have a little house. , and it is built in a 8 M2 room for my frend. And he has a big room for the case.
    We must not forget it is built:
    for 2 Mainbords + a big Watercool sytem with 25 x120 mm rads + compressor cooling .
  18. Egami
    27 Aug 2013
    I was thinking big house from the forklift point of view. It will be very hard to maneuver one in a small flat! Just joking arg-ist. :D It's a great start and I'm looking forward to seeing more! :thumb:
  19. arg-ist
    arg-ist Minimodder
    21 Dec 2013
  20. arg-ist
    arg-ist Minimodder
    21 Dec 2013
