HTPC Just a question
Discussion in 'Hardware' started by Fares, 27 Mar 2009.
  1. Fares
    Fares What's a Dremel?
    7 Dec 2008
    Do you think that is posible to play an 1080i or 1080p Movie on an HD-ready LCD wich is connected with the PC`s graphic card by an HDMI cable.:)
  2. Jenny_Y8S
    Jenny_Y8S Guest
    Yes of course
  3. Fares
    7 Dec 2008
    oh...thank you.so there is no diference between a full HD and an HD ready if it`s connected to PC.thank you again
  4. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    If the monitor/tv is 1080p (full HD) then yea you can play full 1080p content properly, If the monitor/tv is 720p (usually HD ready) then you should still be able to play 1080p but it will scale it i think to fit the lower resolution. Thats what ive always thought anyways.
  5. Fares
    7 Dec 2008
    i have an Hd ready wich suports 1920x1080 resolution. this means that it can play hd contents only in 1080i and 720p even is connected to PC .Right?
