Storage Just bought an SSD, anything I need to know?
Discussion in 'Hardware' started by geoboy333, 1 Sep 2014.
  1. geoboy333
    geoboy333 Sometimes I say something bright...
    28 Sep 2009
    Hi All
    As the title suggests, I have just purchased a Crucial MX100 512gb.
    Having never owned an SSD before I was wondering if there's any 'crucial' info I should know about installing windows on it and general upkeep of the drive.
    It may be just like any other drive but I'd rather be safe than sorry.
    A phrase I often hear alongside SSDs is "Trim". What is it and do I need to bother?
    Thanks
    George
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Just make sure your SATA settings in BIOS is on AHCI mode before installing, Windows takes care of the rest!
  3. geoboy333
    28 Sep 2009
    ah thats alright, my motherboard isn't new enough to have any other option :)
    Good to hear.
  4. Refugee
    Refugee What's a Dremel?
    25 Aug 2014
    Hi, one thing to remember is not to defrag your new drive, SSD's don't need to be defragged and will just shorten life span of drive.
    One other thing I have read about is not allowing your PC to sleep as some SSD drives do not like it and can cause problems have a look here http://tinyurl.com/my63bp6
    I don't even let mine sleep any more just switch it off because start up is so quick
  5. jizwizard
    jizwizard Modder
    24 Dec 2010
    Disable hibernation. It will also free up a few gb of space on the drive
  6. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Is you MoBo the same one that is in your sig ? Because if it is then it should support AHCI, its been around since the days of Vista.
  7. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Windows 7 and 8 are supposed to detect an SSD and disable defragging by default. But always worth a check just to be sure.
  8. shah
    shah Minimodder
    29 Jan 2010
    I don't shut down my PC ever always in sleep mode. Have SSD for the OS and running for almost 2 years I think.
  9. geoboy333
    28 Sep 2009
    Yes it is AHCI, what I meant is it doesn't have any other setting to my knowledge where as new board have a different mode?? maybe I'm getting confused.
    But yeah as far I know it's in AHCI. Where might I look to check for this?
  10. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    you still get the defrag program, but instead of defragging it runs the trim command
  11. Corky42
    30 Oct 2012
    AFAIK it would be on the integrated peripherals BIOS screen, under the heading RAID mode.
