Gaming Just Cause 3 Review
Discussion in 'Article Discussion' started by Dogbert666, 1 Dec 2015.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. faugusztin
    11 Aug 2008
    The grapling hook/grenade thing is not your fault, they switched the bindings between JC2 and JC3.
  3. JakeTucker
    JakeTucker Minimodder
    10 Jul 2015
    That makes me feel slightly better.
  4. faugusztin
    11 Aug 2008
    On positive note, that Prodigy - Firestarter cover at the start of the game made me smile.
  5. JakeTucker
    10 Jul 2015
    Most of the review is positive. I loved this.
  6. faugusztin
    11 Aug 2008
    Also David Tennant as propaganda minister voice in radio probably had lot of fun reading those funny announcements when you destroy a military base.
  7. rollo
    rollo Modder
    16 May 2008
    The game also runs very well on PC. You can tell it's not a port of a game but a game designed to run on the PC.
  8. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    the god awful FOV would like a word with you, jesus **** its so low i swear its single figures
  9. rollo
    rollo Modder
    16 May 2008
    Looks the same as just cause 2 and mad max at 1080p at least.
  10. Hooded
    Hooded What's a Dremel?
    16 Nov 2014
    Fun with guns. And so much more. Shoot em up, blow em up, drag em down
  11. thom804
    thom804 Minimodder
    22 Oct 2009
    I'd read that it was performing poorly across quite a few cards. With AMD even beating out Nvidia with gameworks enabled on some comparable cards...
  12. rollo
    rollo Modder
    16 May 2008
    Me and a friend are both playing it on systems close to the minimum spec with every setting around high and have no issues. Played around 3 hours last night no lag or crashes.
    Gpu and CPU is most people's biggest issue people are assuming incorrectly it's anything above a nvidia 670 but it's the performance of the 670 that it needs to be above. It needs a quad core CPU nothing less.
    I've saw people complaining with nvidia 760s and even the low 9 series.
    People are to unwilling to adjust settings and think everything should be very high. But unless you own a 970+ it's pretty unrealistic at 1080p even let alone above that.
    People where linking there settings on a steam post. Nvidia 960 every setting very high at 1440p and complaining it was a sideshow. Is it really a surprise it's a sideshow.
    I've heard reports it runs very bad below 1080p resolution. No matter settings used.
    I was also streaming the game to twitch channel that I run at the same time.
  13. lacuna
    lacuna Minimodder
    9 Aug 2004
    Quite fancy this when its down to £10 or less
Tags: Add Tags
