Peripherals Just how big is an Logitech MX Master 3 (or 2/2s)
Discussion in 'Hardware' started by The_Crapman, 3 Feb 2022.
  1. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Dealing with some long-ass spreadsheets at work, tons of transactions on the ledger the scroll through, so wanted something with a spinny wheel (that's the official technical term don't you know), and it seems that it's pretty much Logitech or bust. I'm pretty sure a few people here are sporting them and really like them, but I'm a bit worried that it'd be too big for my liking.
    My current mouse is the rat 7 and I don't have the body extended a great deal at all, only one or 2 notches. When using other larger mice my hand tends to sit back and can compromise the crispness and responsiveness of clicks with my short fingers so far back.
    What do you think? Pictures in situ with scale reference points would be appreciated. Also considering an MX Anywhere 2/3. Anything else I should be considering?
  2. sandys
    sandys Multimodder
    26 Mar 2006
    What sort of pictures do you want to see, I have what my friends consider lady hands :miffed::grin: with short fingers and it seems fine to me just heavy, took some getting used to after a deathadder
  3. The_Crapman
    5 Dec 2011
    Coin on top and one lent up the side? I don't mind a heavy mouse, just concerned my spam hands won't fit round the sculpted body.
  4. andrew8200m
    andrew8200m Modder
    4 May 2009
    Go to curry’s website, scan the QR code and have VR place it next to your rat. It’s how I purchased mine :)
    The_Crapman and adidan like this.
  5. adidan
    25 Mar 2009
    Ooh, I learned a new thing, thanks :)
  6. David
    7 Apr 2009
    Is this any use to you?
    Sorry, can't do more right mow - in the midst of a work/covid/staffing rota crisis
    The_Crapman likes this.
  7. The_Crapman
    5 Dec 2011
    Beautiful, thank you. How do you like the fully metal wheels on that, rather than usual rubberised ones.
  8. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    its a lot easier to clean the **** out the grooves, tbh its one of the best mice ive purchased, you'll soon get used to the size/mass and even may prefer it for gaming like I do mine.
  9. giskard
    giskard System builder
    21 Nov 2009
    It’s very light in action, I love my MX3 and wouldn’t go back to anything else.
  10. jinq-sea
    15 Oct 2012
    I'm an MX3 user and I bloody love it. I've got big hands, and it suits me perfectly - metal wheels are excellent too.
  11. David
    7 Apr 2009
    It's a lot heavier than most gaming mice, but I don't do a lot of online fps "twitch" gaming, so it really isn't an issue. The shape is very comfortable to use, which sound like an odd distinction , but it's far more comfortable than the more ambidextrous mice out there; and enough so that I actually noticed the difference.
    It's not plasticky and creaky - it has a quality feel to it. It feels... machined, for want of a better word.
    The easy switching between up to three different PCs is a real boon to inveterate tinkerers like me, too.
  12. The_Crapman
    5 Dec 2011
    Thanks for the feedback all
  13. Krikkit
    21 Jan 2003
    Apologies for diverting OT, but what's the battery life like? My #1 bugbear with a mouse is having to constantly worry about charging it.
  14. David
    7 Apr 2009
    Depends on usage, obviously, but I charge mine around once a month. The charge port is at the front so you can use it like a wired mouse whilst charging it from your PC.
    I bought detachable magnetic charging cables, like these (though not those ones exactly), for both my keyboard and mouse, I just leave the USB C end plugged in to each and have one mag cable that I can connect to either of them without fishing around to find the charge port. It's a pretty clean and hassle-free solution.
  15. Mister_Tad
    27 Dec 2002
    It's good enough that I don't particularly recall when I charged my Master 3 last, and it's on 2/3.
    You can use it whilst recharging like a wired mouse, though it does get a little warm, just enough to be uncomfortable.
  16. Krikkit
    21 Jan 2003
    Ok that's good enough for me! I bought an MX laser a few years ago that barely managed 2 days between charges which was infuriating.
    I'm spoilt with having a succession of Logi Marathon mice (18 months from a pair of AAs) and now the successor of a triathlon which looks like a similar span.
  17. The_Crapman
    5 Dec 2011
    I ended up going for the anywhere 3. Someone at work had a 2s and it felt ok, but my hand was quite far back and I felt like that would make thumb buttons/wheel awkward to reach and use.
    The anywhere 3 is pretty small, but doesn't really bother me at all with my hold. Buttons all align perfectly with my stubby fingers and the wheel is just heavenly. In the 3 weeks I've had it it's only used 30% battery capacity
