Overclocking Just thought I would try the CPC benchmark/Superpi/Cinebench..
Discussion in 'Hardware' started by Guest-44432, 29 Apr 2011.
  1. Guest-44432
    Guest-44432 Guest
    MultiTasking testing started.
    Disabling Aero Glass.
    Re-enabling Aero Glass.
    MultiTasking testing finished.
    Results:
    Image editing: 2112 points.
    Video encoding: 4656 points.
    Multitasking testing: 1920 points.
    Overall score: 2896 points.
    Benchmarks finished.
    2nd run @ 5Ghz
  2. KidMod-Southpaw
    28 Sep 2010
    Great score! Sandy Bridge still comes close.
    Still, you have one hell of a rig there, go play with your big TV!
  3. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Damn you and your far more powerful and expensive Processor.
    Seriously through: that thing must DEVOUR Power under load.
  4. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    Oh a challenge, going to OC my cpu up to 4.5ghz and my gpu to see what i can get when i get home in two hours time just to compare.
  5. Guest-44432
    Guest-44432 Guest
    Will be looking forward to it. I might have to get a bucket of ice and stick my rad in that for some higher clocks, as I'm limited by temps rather than max clock speed.
  6. thelaw
    10 Sep 2010
    Any carbon fire extinguishers in that wagon of yours?
    If you get your rad into a bucket of ice i want to see the pics, that will be entertaining.
  7. sonicgroove
    sonicgroove Radical Atheist
    16 Mar 2011
    there's a post in the mag discussions, where a mate of mine hit 2850 points with a 2600k on air, not bad for a 220 quid CPU really. I could only muster just short of 2600 points@5GHz. It failed to run the tests at 5.25GHz.
    @true_gamer, have you done a superpi 1m run on it yet?
  8. thelaw
    10 Sep 2010
    2600 points is not bad given what you are running compared to the costs of True_Gamers set up...thats the beauty of sandybridge.....i may have to pick your brains on the 4.8ghz settings you have thought..i just went with the 4.5ghz bit tech set up but have yet to play with anything higher..
  9. Tangster
    23 May 2009
    I think a Cinebench run is also in order. I want to see what 6 hyperthreaded 5.02GHz cores can do.
  10. Guest-44432
    Guest-44432 Guest
    Results:
    Image editing: 1985 points.
    Video encoding: 4738 points.
    Multitasking testing: 2024 points.
    Overall score: 2916 points.
    My best so far @ 5ghz, I did try 5.2ghz, but it failed through the test. Temps hitting high in to the 80's
    I really want to break the 3000 max.
  11. thelaw
    10 Sep 2010
    hrumpf!
    Just tried running the tests and ran into this problem and it aborted the tests a few seconds...not sure why its a fresh install of the benchmark suite?
  12. Guest-44432
    Guest-44432 Guest
    Superpi @ 5ghz 200 X 25 HT disabled, will be back with HT enabled, to see if it makes a differences.
  13. thelaw
    10 Sep 2010
    To compare but 4.5ghz on the i5 2500k same calculation and only .300 seconds slower..:naughty:
  14. Guest-44432
    Guest-44432 Guest
    The problem here, is these benchmarks won't use all my cores and threads.
    So you may think your 2500k is as fast, in single threaded apps. But when it comes to multi threaded apps, the 990x will leave Sandybridge in the dust.
    I think we need a new CPC benchmark, that will make use of all my Cores and Threads, to show the true potential of a Hex core.
    Cinebench thelaw? I will set my Cpu @ 4.5Ghz:D
    Teelzebub likes this.
  15. thelaw
    10 Sep 2010
    Yes agree need a multi thread test to compare both our Cpu's against each other..
    As for cinebench...running it now..
  16. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    i5 2500k@4.5Ghz w/ 2x4Gb @ 1600Mhz:
    Image editing: 2005 points.
    Video encoding: 3600 points.
    Multitasking testing: 1553 points.
    Overall score: 2386 points.
    I beat you in the Image Editing.... o_0 wtf
  17. Guest-44432
    Guest-44432 Guest
    Not when you compare my first run:D
  18. murraynt
    murraynt Modder
    6 Jun 2009
    Are you going to try 32M?
  19. Guest-44432
    Guest-44432 Guest
    1st run @ 4.5ghz HT enabled 145 x 31
  20. thelaw
    10 Sep 2010
    B**tch
    If you also want to show me up more...here are my furmark test bearing in mind i am running a tiny Acer AL1715B 17" TFT 12ms 450:1 (1280x1024) :rolleyes:
    I ran furmark for my GTX 460 first at 815mhz for about 3 minutes, my temps are in the stats below 60c
    and again at 850mhz for 5 mins i was hitting just above 60c
    Guest-44432 likes this.
