Case Mod - In Progress K.3nny's LianLi Pc-7HX Casebuild, acrylic pipes - Voting time :D!
Discussion in 'Project Logs' started by k.3nny, 20 Nov 2012.
  1. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Back again with again a lianli case :D!
    Package arrived
    Some seconds later
    Dismantled the case and start measering things out.
    Made an working table.
    The first adjustment will be the front.
  2. KidMod-Southpaw
    28 Sep 2010
    Nice to see you back! I'm looking forward to this!
  3. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    @KidMod, Thnks buddy!
    Update
    Started with the top and front,
    some masking and lining everything out.
    Raw cut
    After some elbowgrease ;)
    Then i started with the front, removed original frontpanel mesh, Tried some lianli mesh from another case on the drivecage area but Nah, thats not it.
    I didnt want the Dual 14mm intake, so i fixed a plexiglass window for it, still not done ofc ;) waiting on some stuff.
    Mounted
    Started with the top plexi window,
    rawcut
    After some elbowgrease and P400 sandingpaper
    Nice and smooth!
    To the next update!
  4. Sissilisko
    Sissilisko What's a Dremel?
    26 Apr 2012
    waiting to see what's coming :p
  5. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Ah not much ;)
  6. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    update time!
    Psu relocation + searching for watercooling opertunities
    Voiding the warranty like a boss!
    Lets find a place for that naked psu!
    Well thats a nice spot isnit?
    Some motherboard standoffs to mount the psu-pcb to the case
    i did a good job, with to standoffs :D
    deleted some more Aluminium from the case.
    gonna mount the fan on an angle, so it gets fresh air (update for that incomming) and blowns the air to the headspreaders, and pcb.
    Thinking about this layout, but i need a mcp355 pumptop to confirm this loop, so thats on hold untill i got the top.
    Greets!
  7. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    Wow brilliant idea !
  8. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Thnks silver!
  9. alain-s
    alain-s Minimodder
    12 Jan 2011
    Looking good Kenneth lovely solution for the PSU :D
  10. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Update :D!
    Created an "intake" so i had no airflow isseus with the psu
    Then i sawed of the mounting side of the psu INCLUDING the inline filter, so its all 1 part and not 1 thing here and 1 thing there (oh wait, xD! )
    Today also came 2 packages in the mail, 15meter of red paracord sleeving and 50x152cm matte black vinyl (still wanted to try that and i kinda like it)
    Cleaned the front, no more fans there, because the hole innerside will be random build :p
    * matte black blends in perfectly with brushed alu!
    My psu was already sleeved with MDPC sleeving, but i wanted to go heathshrink less, so i took paracord :).
    when sleeving all wires 1 at a time i created this wire pass thru.
    *also ripped a piece of metal away so i can let the wires guide at the back of the motherboard panel:)
    also my top a step further, more about that tomorrow.
    see u with the next update ;)
  11. exexs
    exexs What's a Dremel?
    4 Mar 2010
    The PSU idea is just... marvelous! So much free space in the bottom of the case now.. :)
  12. mybadomen
    mybadomen What's a Dremel?
    19 Jan 2012
    Great job K3nny
  13. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    subbed
  14. Guest-16
    Guest-16 Guest
    PLEEEEASE isolate all that PSU stuff so you don't end up with a 110/220V Lian Li electrode.
    How are you doing the power connectors? Very interested!
  15. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Thnks and yes its something different ;)
    Ty dave :D!
    Ty
    Dont worry mate, Everything will be isolated, just wait for the update ;):blush:
  16. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    update :)
    top window done and finished off with a black matt vinyl edge
    Bought myself some aluminium
    500x1000mmx1mm
    Drawing all the plates on the big plate and cut them to size :)
    Frontplate innerside.
    Ready to bend.
    Psu plate is done :D so happy this went good :D!
    Mounted
    Reservoir spot.
    Midplate done!
    creating some tabs to mount the midplate on.
    Thats straight :D
    Radiator placement ? :)
    See u next time ;)
  17. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    update!
    Creating the hole for midplate
    Jigsaw time!
    Perfect!
    Creating 2 pass thru's
    Used realy strong gleu to hold up the rad against the midplate, so its supper clean :)
    started with some matt black vinyl to create some finished looks
    midplate
    frontplate
    psu plate
    Overall for today
    See u guys next time :)
  18. Ra6
    Ra6 What's a Dremel?
    4 Nov 2012
    THAT IS an impressive job! It's perfect!
    By the way, I haven't seen anything like that before, but if I'm right, you plug the PSU on the bottom of the case and it runs on the 5.25" bays place isn't it?
  19. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Quality work
  20. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Treu, And thanks :D!
    Ty sir!:thumb:
