Case Mod - In Progress K.3nny's LianLi Pc-7HX Casebuild, acrylic pipes - Voting time :D!
Discussion in 'Project Logs' started by k.3nny, 20 Nov 2012.
  1. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Love where this is heading :)
    especially liking the roof window :D
  2. fractal arc modder
    fractal arc modder What's a Dremel?
    12 Aug 2011
    This is going to be one epic build
  3. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Doing me great that people are willing to put some effort into reacting on builds, more reactons - more updates, Counts for all buildlogs!:dremel::dremel::dremel:
  4. Paslis
    Paslis Minimodder
    13 Jun 2011
    Awesome job so far Kenneth. :D Waiting for the next update. :D
  5. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Thnks :D! Yes i need some little parts then i can move the hardware and finish it up :)
  6. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    update,
    Well, My budget has reached his max point (49 euro) so yeah, All i can do is take the my daily and strip it down so i could do the heart transplant :p also using some other parts :)
    Also created a new powercable fot the pump and sleeved it :)
    Because i was so busy i forget to take pictures, i spend around 6 hours today on the setup and case.
    Here some random pics, less text more pics :D
    Thats it for this update :D!
    Main point was i could re-use 3 pieces of solid tubing, glady saved me 10 euro on a new 2 meter acrylic pipe!
    Budget modding is always fun to do, and see what u can realy achieve with less expensive things
    Costs:
    Case: 110 euro
    Alu sheet / paracord: 25 euro
    Splitted order with a pal HighFlow.nl: 60 euro 20 Euro my costs
    2 liter Demiwater: 4 euro
    Mat black vinyl : Free
    Total 159 euro
    Got 1 euro left, The point was i had some things laying around, could save on those allot :)
    Bye guys!!
  7. Sam__
    Sam__ Minimodder
    22 Sep 2012
    good job on the re-using and a nice job on a budget.
  8. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Ty sam!
  9. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Making Acrylic tube yourself!
    Time to explain how to make acrylic tubing * my english is not THAT good!!!!
    First of al, search and use object for the bends, i prefer steel, it keeps the heat stuck, and doesnt cool down your acrylic pipe that quick.
    Always make the tube longer than u need!, the bends can not come out how u want sometimes (weakspots)
    I use a Power suply 7mm thick cord (EU)
    I prefer a hairdryer, because u cannot overheat the tube and it wont make it to warm so you pull the tube flat.
    If the tube is hot enough, u cant start bending the pipe, dont pull to hard otherwise u get a flat spot at the end of the pipe.
    If u are at the point that your tubing is bend and lined up with the fittings u can cut it to size
    I used a cheapo rotary tool and a dremel atachment (sanding barrel P120)
    My working situation xD!
    Tape it 7/8mm of the edge, so you know you dont get an ugly spot above your fitting
    only sand the tube till its frosted! dont use pressure, dont create flatspots, the pipe is sold as 12mm but the exact size is 12.3/12.7! so yes just a little touch all around is enough! finish it up with sandpaper Grid P400 so the rubber ring wil fit nicely!
    Test the fitting
    Thats it for this little guide :)
    Further on with this update!
    ready to be cleaned and Filled up :D!
    Waterrr
    Dirty loop
    After draining the loop, i put fresh and new water in it, Then started to play with Mayhems red Dye!
    1 drop
    2 drops
    3 drops
    4 drops
    5 drops
    6 drops
    Gonna leave it like that for now, maybe some more or ill thin it up, we will see in the future :)
    Rest of the pics.
    :thumb:
    Bye bye:hip:
  10. Sam__
    Sam__ Minimodder
    22 Sep 2012
    I really like the look of that bent acrylic pipe.
  11. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    Yep that pipe looks much better than tubing. nice work and thanx for showing how you did it.
  12. Bitwacker
    Bitwacker C# forever
    9 Nov 2009
    Brave to strip a PSU; you must be a ninja
  13. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    Thanks for the tutorial!
    I still can't decide whether I should use nickel or acrylic tubing in my next build...
  14. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Thnks :D!
    No problem glad to show off the things you can do :)
    Nah, Just Challenge accepted ;) its still running flawless, i had it on prime 95 and furmark for some stresstests :) nothing changed, i think i did a good job
    Acrylic is the way man :D!
    :dremel:
  15. elAwesome
    1 Nov 2012
    Reasons? :p
  16. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    no stains :D always perfect sight :p
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    Awesome mod Kenny. :)
    Nice result from a hair drier too, thanks for the tut. :D:clap:
  18. exexs
    exexs What's a Dremel?
    4 Mar 2010
    wooah. I got a similar case (lian li pc-9f) and what you have done is very different from any integration sketch I did :) That is what makes me believe you job is great! ^^
  19. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Thnks guys :D!
  20. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Looks realy cool. Me like the idea of using those plastic tubes :)
